Old 06-08-2011, 07:28 AM   #1
smagerstein's Avatar
Unhappy Need Help!!! Instrument Cluster Problem
Hi all,
Im hoping someone here may have some advice please!!!
Last weekend I finally decided to install new face dials on my 2002 Box. (yellow Gambella dials!! which look great!)
So I downloaded and followed word for word instructions from the web. (found the link here). No problem, very easy actually. Very delicately removed everything and replaced in exactly the same place as before.
Fine, everything worked ok except the rev gauge...... So, pulled everythingy apart and checked the blue and green plugs to make sure they were in ok. Then everything failed except the temp gauge.
So im scared to try anything again. At this point all the digital info works fine and the temp gauge. I have no speedo, I have no rev gauge and no fuel gauge.
Anyone here know what to try????? Im out of ideas.
Porshes answer is to replace the whole instrument cluster for 2500€!!! Ill try anything first......then ebay as a last resort.
Thanks.
Steven Magerstein
2002 Boxster 2.7 Seal Grey
2008 MB C200k
Past Cars
2006 MB C180k
2005 Peugeot 306
1980 928
2004 Subaru Liberty GT
2000 Nissan Pulsar SSS
smagerstein is offline   Reply With Quote
Old 06-09-2011, 05:44 AM   #2
Originally Posted by smagerstein
Hi all,
Thanks.
Did you disconnect the battery prior to removing the cluster?
2001 Boxster S 3.6, 2003 E46 M3, 94 968 Cab, 80 911 Weissach Edition, BMW 1200 CLS
smshirk is offline   Reply With Quote
Old 06-09-2011, 10:20 AM   #3
the plugs just aren't seated properly. i doubt you've done any permanent damage.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
Old 12-24-2013, 09:39 PM   #4
Where can I get the yellow dials you mentioned?
unman is offline   Reply With Quote
Old 12-24-2013, 09:45 PM   #5
I am my own mechanic....
Timco's Avatar
Only took you a year to get past that first post!
'08 VW Touareg T-3 wife's car
Old 01-04-2014, 03:42 PM   #6
Lake Macquarie is in AUSTRALIA!
It just takes longer for we Colonials to receive information from your area.
Are you going to tell me where I can get the yellow instrument cluster faces?
Old 01-05-2014, 11:01 AM   #7
Damn Yankee
TeamOxford's Avatar
Try here:
Gemballa USA
Gemballa may have a branch down under. Do some searching.
TO
