Originally Posted by smagerstein
Hi all,
Im hoping someone here may have some advice please!!!
Last weekend I finally decided to install new face dials on my 2002 Box. (yellow Gambella dials!! which look great!)
So I downloaded and followed word for word instructions from the web. (found the link here). No problem, very easy actually. Very delicately removed everything and replaced in exactly the same place as before.
Fine, everything worked ok except the rev gauge...... So, pulled everythingy apart and checked the blue and green plugs to make sure they were in ok. Then everything failed except the temp gauge.
So im scared to try anything again. At this point all the digital info works fine and the temp gauge. I have no speedo, I have no rev gauge and no fuel gauge.
Anyone here know what to try????? Im out of ideas.
Porshes answer is to replace the whole instrument cluster for 2500€!!! Ill try anything first......then ebay as a last resort.
Thanks.
Did you disconnect the battery prior to removing the cluster?
2001 Boxster S 3.6, 2003 E46 M3, 94 968 Cab, 80 911 Weissach Edition, BMW 1200 CLS
