08-31-2009, 09:14 AM
#21
Originally Posted by pk2
We have the most stringent emissions standards in the land...might not fly.
A lot of states have stringent emissions standards, mine included; and as we have about a dozen or so clients running around with the 160 stats, and passing state emissions testing, I don’t see an issue.
But, the point made here several times is you want your coolant cooler so the oil is cooler. Well, they don't seem so directly related. Obviously my oil temps of 188f (assuming good methodology) are lower then the 210 every body is talking about & the oil has it's own cooler (no?). So again, begs the question,Forget the water, How hot should your oil be?
Actually, they are directly related due the oil/water oil cooler used on the M96 design. In fact, one of the best “bang for the buck” upgrades on a 2.5/2.7 base car is to install the “S” cooler because it is more than twice the size of the base unit. With the coolant running 210-215 normally, the oil is going to be 25-35 degrees warmer under cruise usage (not to mention how hot it gets under load or in high ambient temps); drop the coolant temp 20-25 degrees, and the oil comes down with it…………..a major gain for the oil and life of the M96.
BTW; In my BMW3.0 coup days, we used to just drill holes around the perimeter of the thermostat. They were really accessible so trial an error was easy.
The M96 stat already has a hole in it………..
08-31-2009, 09:18 AM
#22
Originally Posted by Blue-S
When you say the dash gauge indicates 180, where is the needle pointing? Is it straight up, between the "8" and the "0"? I contend that the tic mark above the "8" is the 180 degree position, and the common cruise position (straight up, between the 8 and the 0) is intended to indicate HOTTER than 180 degrees. The gauge is certainly non-linear, and was apparently not designed to provide a precise temperature indication. If they had used a more serious-looking font, maybe they could have placed the number markings in a centered position below each respective tic mark. Maybe they should have just left the numbers off of the gauge altogether...
Typically, we use the middle of the “8” as our reference point, and when the needle is there, the coolant is 210-215F; go past that and it gets even hotter, often reaching 225F by the time it is over the “0”. Because of the non linearity of the gauge, the relationship of position to actual temp is very misleading……
08-31-2009, 11:37 AM
#23
JPA_PA
Yup you do, Your a "CARB state", California has special status, its sets it's own standards, other states can choose between weak Fed standards and tough CA standards. PA and others follow CA. Lucky us lucky you. Unfortunately with the motor totally re-tuned for the blower, I barrrrrely squeaked by ...at idle no less!?!
A water to oil cooler makes them (the fluids) the same temp and that is 220-210, O.K. Why does my oil appear to be 188f. If you read my methodology & you get the logic, I think it's pretty sound. If you got a better method, let me know. Punch holes in mine. I don't care as long as the the numbers add up.
Funny thing though, I suppose if I already had a 160 thermostat (or 140 (?)), oil at 188f might be just about right and we could all go home. (Gotta get a good read on the coolant temp I guess.)
Regards, PK
BTWx2. Porsche has "a' hole in the thermostat, quaint. We just kept drilling till it worked right. 3 or 4 holes I think was the magic number. Did take longer to warm up though.
08-31-2009, 12:25 PM
#24
JPA_PA
The problem is your methodology; you are not measuring the actual temperature of the flowing oil, you are measuring the outside metal of the sump using and indirect (non contact) method…………..there is no way your oil is circulating at 188F if you are running the OEM stat……………The M96’s coolant is pulling heat out of the oil once the engine is up to operating temperature, the oil typically is running 20-30F higher than the coolant…………………….
08-31-2009, 03:11 PM
#25
temp display
I will have to drive my 2000 "S" this evening and look at how the HVAC control panel diagnostic mode display for coolant temp compares with the needle position on the gauge. I should look at oil temp, too. Right now, ambient temp is in the neighborhood of 100 degrees in the inland areas of Southern California.
Here's the procedure for putting the HVAC panel in diagnostic mode:
Originally Posted by Lil bastard
On '97-'00 cars, you can access the diagnostics by holding the recirc and Air ↑ buttons for about 5 sec. Now you're in the diagnostic mode. The + - buttons allow you to scroll through the 36 different codes. The center button switches the display (left) from the code # and the actual value. To exit diagnostic mode, press Auto.
0c - ERL
1c - Oil temp
2c - Cabin temp as measured from the sensor mounted at the side of the dash.
3c - Outside temp - from AC air inlet
4c - Outside temp from ambient temp sensor on front grill (continuous)
5c - Outside temp feed from OBC display (5 sec. sampling and hold when stationary)
6c - Coolant temp
7c - Footwell discharge temp
8c - Sun sensor
9c - Sun sensor
10c - Cabin fan speed
11c - Cabin fan voltage
12c - Temp mix flap - 1=Cold, 100 = Hot
13c - Temp mix flap position
14c - Central flap cmmnd.
15c - Central flap position
16c - Footwell/defrost flap cmmnd.
17c - footwell/defrost position
18c - Recirc valve cmmnd - 1=Off, 100 = On
19c - Recirc valve position
20c - Vehicle speed in KPH, 1 sec. sampling, actual speed - no safety margin
21c - Engine RPM (hundreds) - 1 sec. sampling
22c - ??
23c - ??
24c - Display panel illum. voltage
25c - ??
26c - ??
27c - ??
28c - Fan speed
29c - ??
30c - Engine run time in sec. (255 max.)
31c - timing counter
32c - Display test
33c - Sftwr. ver.
34c - ??
35c - Outside temp from inlet sensor post filter
36c - Temp.
This unit is built by audi and the codes marked ?? have to do with different applications.
Blue-S
2000 Boxster S 6-speed - Ocean Blue / Savanna Beige
* 9x7 short shifter * Pedro's enthusiast mount * Carrera Ltw. wheels * Stebro bypass pipes
* M030 coming soon! *
09-01-2009, 01:50 AM
#26
Blue_s.
Let me know what you find. I think I have that setup too but quite frankly, I never saw much of interest. Looks like you have though. Be nice to see some alternative numbers.
Only a hundred in Corona eh? It was 97 the day I did my test, about as hot as it's been, I live about 40 mi. south west of you. Figured at least 110 further inland.
Regards, PK
09-01-2009, 01:59 AM
#27
JFP in PA,
Working on a rebuttal. Have dyslexia but good. Takes forever to write something legible.
You make some good points but I think I have you on a few. To one point, you might look-up "digital laser pyrometer" on Wikipedia or wiki-answers (for simple answer).
Regards, PK
09-01-2009, 09:49 AM
#28
JFP in PA,
Regards, PK
Actually, as I already own two of them, a look up is not required, I know how they work, and their level of accuracy..................
09-01-2009, 01:33 PM
#29
Ya I guess not, ... perfect. You just saved me about an hour and a half trying to explain and key in what it's all about.
So, with this one, Ive measured quite a few different materials (including my head, including aluminum) and from different distances in different ambient environments etc. pretty accurately (used a standard scientific thermometer to verify a few). At the Lab I've seen them take pretty precise measurements at at least 1400 degrees. The only thing I can't measure is flame.
Since all it it sees is infared (IR), not the material or you or me, and the IR is all the same no matter where it comes from, and all it does is measure the intensity iradience) of the IR. Why do you think it can't accurately read the temp of this particular aluminum alloy of the sump?
Listen, I really appreciate you humoring me and sticking around. I think I just have one more thing that doesn't quite compute for me, and then I'll leave you alone.
It's sounding like this may be a genuine good thing.
Regards, PK
09-01-2009, 01:49 PM
#30
I’m sure that the infra red pyrometer is measuring the surface within its stated limit of accuracy; that said, the thermally conductive outside of a casting is not an accurate reading of the circulating oil or coolant. If you want to accurately monitor them, you need to have probes immersed in the actual fluid while it is circulating; and not trying to interpret the fluid temps by inference from the outside of the casting.
Accurate, and closely tested temperature gauges attached to the M96 with their probes inserted into the fluids while running consistently show much higher temps than you see on the outside with a non contact pyrometer, often 35-45 degrees F higher, even at the surface of the oil cooler. We have collected data off of multiple M96 engines in this manner, and have never seen a non contact unit get even close to the actual temperatures. So, no, I do not trust or believe in non contact measurement as being anything more than an inference or presumption of the actual operational temperatures of the fluids…….
09-01-2009, 02:14 PM
#31
www.klisstle.com
I will have to drive my 2000 "S" this evening and look at how the HVAC control panel diagnostic mode display for coolant temp compares with the needle position on the gauge. I should look at oil temp, too.:
After recently installing a new water pump, 160F thermostat and new coolant in my 2000 2.7 I've been monitoring my coolant temperatures. With ambient temperatures in the mid-eighties and speeds in the 70 MPH range I'm running between 80-85C (176-185F). When I slow down or stop in traffic the temperature quickly rises to 95-99C (203-210F). I haven't cleaned my radiators in 5 years so I assume they aren't ideal. I haven't yet looked at oil temperatures but will on the next outing.
Curious to see what you are running with your S.
ddb
09-01-2009, 05:07 PM
#32
That's typical. The only way to keep the coolant at the cruise temp is to make the fans come on earlier. There's a thread on the 996 forums at Renntech on how to do the mod:
http://www.renntech.org/forums/index.php?showtopic=28093&st=0&p=148785&#entry148785
I plan on doing this mod to our Boxster myself as I see the very high trigger point for the fans as the real limiting factor.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
09-01-2009, 05:48 PM
#33
I will have my car back from Raby soon with, amoung other stuff, a 160 Stat, however lets take this thinking to the extreme.
If lower is better, what would happen if the Tstat was removed and water was allowed to flow unhindered?
Not to hijack, just to understand better.
2002 S
09-01-2009, 06:14 PM
#34
www.klisstle.com
I think the water (and maybe oil) temperatures could be too low for too long. Maybe not a big issue in your climate, but in colder areas you wouldn't have any (or enough) heat. Engine oil and coolant temps. too low probably isn't good for the engine just like too hot isn't ideal.
09-01-2009, 08:01 PM
#35
Engine Surgeon
Removing the T stat makes the engine run HOTTER.. The coolant goes through the radiators too quickly to cool.
09-01-2009, 08:25 PM
#36
No problem
I like that attitude. I can see your ratcheting it up bit by bit.
I did take the thermostat out of my old 6cyl bmw cs coupe a long time ago. The problem was it never really warmed up. In fact it was down right cold, in the blue at speed somtimes.
With alot of trial and error, I think 3, 1/8th" holes through the thermostat gave me the temp I wanted (140??...maybe?). To be honest though, I didn't really notice a diff. Only that as db said, it took a little longer to warm up. I guess we're talking 5 hp here? I built the whole engine and tweaked quite a bit. 5 hp just might not have registered.
But, I think I agree with db, It's used to be, and I pretty sure it's still true to a degree, only when the engine was warmed up and running within a certain temp window that all the moving parts have expanded and fit together correctly as designed (we hope). So in a way I think driving around a cold engine is just as hard on it as driving it to hot.
Anyway, pop in any time. I'm the hijacker here. Till I arrived this thread was about changing a water pump. PK
09-01-2009, 09:54 PM
#37
Originally Posted by ddb
After recently installing a new water pump, 160F thermostat ...traffic the temperature quickly rises to 95-99C (203-210F). I haven't cleaned my radiators in 5 years so I assume they aren't ideal. I haven't yet looked at oil temperatures but will on the next outing.
ddb
DB, your fans aren't turning on very early. Mine come on within a minuet or 2 of hitting traffic. Once It''s warmed up, for what it's worth, the needle doesn't move much.
Don't know what your using for coolant, pretty sure it's not your prob but, your ready for a change. Might consider something like a quality version of GM.s Dex cool. Most of us traitors use Xerex dex-cool (compatible), about 1/5th the price of Porches exclusive juice and chemically identical where it counts (no silica or phosphates).
You probably knew all that already. If not, don't trust me, do some research. That's how I figured it out. It may still be controversial, so is the current issue at hand though.
Regards, PK
09-01-2009, 11:28 PM
#38
I had some time this evening to drive a bit and collect some data from the HVAC control panel's diagnostic mode as explained above. The car was a 2000 Boxster S 6-speed, with a new Porsche water pump and a 1-year-old standard replacement thermostat (presumed to be 80 deg C). The A/C compressor was off throughout the testing.
* During warmup, with the temp gauge needle exactly on the "tic" mark above the "8" in the "180" label, the HVAC panel (in 6c display) read 79 degrees C coolant temp. That converts to 174 degrees F.
* After allowing coolant temp to stabilize by driving approximately 10 miles with cruise set at 71 mph indicated in the digital speedometer display, I saw the following in the HVAC panel diagnostic mode:
Outside Temp Average (5c display) = 30 deg C (converts to 86 deg F)
Coolant Temp (6c display) = 91 deg C (converts to 196 deg F)
Vehicle Speed (20c display) = 111 km/h (converts to 69 mph)
RPM (21c display) = 2700
The coolant temp gauge needle in the instrument cluster was pointing straight up between the "8" and the "0" of the "180" label.
Oil temp was unavailable in the HVAC control panel diagnostic mode, because (I think) the 986 Boxster does not have an oil temp sensor in stock form.
When I returned home, I idled the engine for a while and gathered some more data:
* at 100 deg C (6c display on the HVAC) the gauge needle was approximately in the middle of the "0" in the "180" label.
* at 102 deg C (6c display on the HVAC) the right side radiator fan came on. This correlates with the specification in the Bentley manual for HIGH speed (stage 2) fan. The coolant temp crept up to 104 deg C (219 deg F) and stayed there for at least 5 more minutes with the right side radiator fan running. The gauge needle was at the right edge of the "0" of the "180" label when the HVAC was displaying 104 deg C coolant temp.
It is apparent that I have a radiator fan problem on my car. According to the wiring diagrams, both left and right side fans should be controlled at the same speed (stage 1 or stage 2) at the same time. It should be pretty simple to begin testing at the relay locations under the dash, since the relays seem to follow the standard ISO terminal definitions. I'll start with my Fluke 88 meter and a fused jumper wire...
So, what's going on here? These coolant temperatures do not match what JFP in PA, cnavarro and Jake Raby have posted on multiple occasions. Is the DME lying to the cluster and/or the HVAC control panel? Is the cluster lying to the HVAC control panel? Is the HVAC control panel lying to me? Or is the HVAC panel diagnostic mode accurately reporting the coolant temp as the DME reads it from the ECT sensor? None of the scan tools I have access to will read DME data, so this might be the push I need to buy the Durametric package...
Blue-S
09-02-2009, 01:03 AM
#39
Blue s,
Great work. So what has been said appears to be true. Have to ponder a bit...Think I'll see if I can get the same in my car... maybe I can even get the oil temp.
Let ya know whhat I come up with.
Regards, PK
09-02-2009, 06:24 AM
#40
I have never used the climate control panel, so I cannot vouch for its level of accuracy, or how it compares to those seen on a scanner. You also need to recognize that these cars do vary somewhat in the temperatures they run at, even with the LN stat, due to differences in the cooling system (debris in the radiators, condition of the pump, non linearity of the dash unit, etc). I do know that the water temperature senders, at least those I have had the chance to evaluate, are pretty accurate. When using an OBD II scanner to monitor coolant temps, you are seeing the actual sensor data being relayed to the DME, so the numbers are also pretty reliable, and have correlated well with aftermarket gauge setups in the same cars.
On the Boxster, you cannot see the M96’s oil temperatures with out adding an oil temperature sensor to the engine, and while it can be done a couple of ways for testing, it is not a practical setup for day to day driving; so we only have used it for test purposes.
