I will have to drive my 2000 "S" this evening and look at how the HVAC control panel diagnostic mode display for coolant temp compares with the needle position on the gauge. I should look at oil temp, too. Right now, ambient temp is in the neighborhood of 100 degrees in the inland areas of Southern California.
Here's the procedure for putting the HVAC panel in diagnostic mode:
Originally Posted by Lil bastard
On '97-'00 cars, you can access the diagnostics by holding the recirc and Air ↑ buttons for about 5 sec. Now you're in the diagnostic mode. The + - buttons allow you to scroll through the 36 different codes. The center button switches the display (left) from the code # and the actual value. To exit diagnostic mode, press Auto.
0c - ERL
1c - Oil temp
2c - Cabin temp as measured from the sensor mounted at the side of the dash.
3c - Outside temp - from AC air inlet
4c - Outside temp from ambient temp sensor on front grill (continuous)
5c - Outside temp feed from OBC display (5 sec. sampling and hold when stationary)
6c - Coolant temp
7c - Footwell discharge temp
8c - Sun sensor
9c - Sun sensor
10c - Cabin fan speed
11c - Cabin fan voltage
12c - Temp mix flap - 1=Cold, 100 = Hot
13c - Temp mix flap position
14c - Central flap cmmnd.
15c - Central flap position
16c - Footwell/defrost flap cmmnd.
17c - footwell/defrost position
18c - Recirc valve cmmnd - 1=Off, 100 = On
19c - Recirc valve position
20c - Vehicle speed in KPH, 1 sec. sampling, actual speed - no safety margin
21c - Engine RPM (hundreds) - 1 sec. sampling
22c - ??
23c - ??
24c - Display panel illum. voltage
25c - ??
26c - ??
27c - ??
28c - Fan speed
29c - ??
30c - Engine run time in sec. (255 max.)
31c - timing counter
32c - Display test
33c - Sftwr. ver.
34c - ??
35c - Outside temp from inlet sensor post filter
36c - Temp.
This unit is built by audi and the codes marked ?? have to do with different applications.
