Old 09-15-2008, 12:39 PM   #1
Wheel Offset Question
May sound a bit nieve....but is the higher the offset ie 58 the fuller it fills the arches or is it the lower number that fills them !
thanks guys
kegman is offline   Reply With Quote
Old 09-15-2008, 01:57 PM   #2
thanks guys
lowering the wheel offset pushes the wheels out. example: you have a 65mm offset. you add a 20mm spacer, pushing your wheels out by 20mm. your new offset is 45mm.
insite
'99 Boxster
3.4L Conversion
Old 09-15-2008, 04:13 PM   #3
The higher the number, the more it will fit inside the wheel well.
Example, a 52mm offset will stick out past the fender edge compared to a wheel with a 58mm offset.
Rareair is offline   Reply With Quote
Old 09-15-2008, 10:56 PM   #4
Send a message via AIM to EvilTwin
I have found this site to be of great help determining proper offsets www.1010tires.com/WheelOffsetCalculator.asp . It helped me fit 17" Boxster twists on my 1969 VW Beetle. I try and stay neutral with the offset I run because I plan to lower my '01 S and I don't want to roll the fenders.
EvilTwin is offline   Reply With Quote
