Originally Posted by kegman
May sound a bit nieve....but is the higher the offset ie 58 the fuller it fills the arches or is it the lower number that fills them !
thanks guys
lowering the wheel offset pushes the wheels out. example: you have a 65mm offset. you add a 20mm spacer, pushing your wheels out by 20mm. your new offset is 45mm.
