Old 07-17-2022, 03:11 AM   #1
996 3.4 intake manifold on 986 boxster S
Hello. I own 2001 boxster s. My car has 3.4 heads. Since I don't have a 3.4 manifolds, I was using a 3.2 manifolds. Now I have 996 3.4 manifolds and I have them installed in their original holes in the heads. My problem is the right manifold is touching the top plate of the engine compartment (red marker) I think I need to lower the engine by 1.5" inch. I also thought of cutting the area where the manifold touches, but this time I think I can't pass the shifter cables from the top, I would have to tighten them under the manifold. I don't know which way to follow. Just lowering the front of the engine without touching the trans is it very difficult? Is there anyone who can help with this?
evrren is offline   Reply With Quote
Old 07-17-2022, 10:46 AM   #2
If you search the forum you'll find that this topic is quite well covered. Lowering seem to be the way, search for details..
Btw, I thought the 3.4 heads where the same as 3.2... Maybe I'm wrong.
Old 07-17-2022, 05:23 PM   #3
Lowering the engine on an already lowered car is asking for trouble imo. If you don't believe me, crawl underneath and see how many of your transmission cooling fins are still intact.
I would cut the metal around the intake. If you keep it localized to the seal area, you will never notice the difference. Woody and I both did this to facilitate intake mods without problem. Running the shifter cables under the headers are inconsequential so long as you don't damage anything while threading the cables through.
Old 07-19-2022, 02:55 AM   #4
Any pics of how you cut it?
Old 04-05-2023, 02:21 PM   #5
Bumping this one...
@Ike any chance you'd share a picture or a little more info on how you did the cutting?
Old 04-05-2023, 02:31 PM   #6
78F350's Avatar
Originally Posted by Robert986 View Post
Bumping this one...
Here's how Woody did the cut for the 3.4 intake. Note: This car is a salvage car that was rebuilt for rallycross, not made to look pretty.
Old 04-05-2023, 10:41 PM   #7
Thanks 78F350!
Thats's a bit to brutal for me, thinking of resale value.
I wonder if one can cut down the edge of the actual intake a bit or find some other way?
Old 04-06-2023, 08:15 AM   #8
The Radium King's Avatar
or bend it and bend the cover to match. noting 987 cover has a bit more clearance.
also lower the motor 1" or so - spacers at the motor mount, 993 transmission mounts.
Old 04-06-2023, 06:48 PM   #9
Sorry, I missed that post. I'll get pics posted this weekend.
I used the stock 986 intake runners, just had to make a small notch for the new intake tubing. You can't even see it with the cover on.
Sent from my SM-N975U using Tapatalk
Old 04-06-2023, 11:11 PM   #10
Pics
Old 09-15-2025, 03:05 PM   #11
Any updates? Juice worth the squeeze?
I already have intake and exhaust on my 986S. I saw a Dyno video of intake/exhaust vs intake/exhaust/IPD plenum/TB. The plenum and TB caused like a 20 HP drop at certain points for very minimal gain up top. Curious peoples thoughts on going with the 996 Mani/plenum/tb
Mangosmoothie is offline   Reply With Quote
Old 09-16-2025, 04:56 AM   #12
The guy I had assembling the bottom end (yes, I'll do it myself next time!) wanted me to put some 996 heads on it, but I already had some originals machined so I passed. He says it makes a difference. He should know since he works with one of the big Boxster parts sources and builds many engines--including the 4.0 in his 996.
-H. L. Mencken
Old 09-16-2025, 03:07 PM   #13
Disregard, incorrect info. Edited to delete
