Old 02-04-2020, 09:26 AM   #1
LN Spin-On Oil Filter Adapter
It's been a while since this topic has come up, and it's an upgrade I've been considering for quite some time to make DIY oil changes a bit more convenient.
Now that these have been out for a while, can any issues or failures be contributed to their use, given that the filters used don't have a bypass?
Thanks!
1998 Porsche Boxster - Ocean Jade Metallic
1985 Porsche Carrera Targa - Guards Red
1978 Porsche 911SC Euro Non-Sunroof - Grand Prix White
Seadweller is offline   Reply With Quote
Old 02-04-2020, 10:11 AM   #2
AZ986S's Avatar
IMO, full flow guarantees full filtration. Another benefit is that it helps when IMS grenades or bearing goes. The pressure relief valve will take care of relieving pressure were there blockage of the filter. And you can get synthetic media filters vs the OEM paper filter. All wins to me. I have mine remotely mounted so even more options there like racing filters etc... And I can use a taller filter.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
Old 02-04-2020, 10:40 AM   #3
husker boxster's Avatar
I've had one on my CSS, which is my DE car, for a long time. Felt it was a good idea to have a metal filter if I ever did any agricultural driving. Didn't want to knock off the plastic canister. Last fall I had a constant drip by the oil filter. Would tighten it a bit more and clean it off. Cpl wks later, more drips. I knew the filter was on tight. Got on the LN site and found there was a gasket replacement set for sale. It seals the adapter to the engine block. I looked back at my records - I bought the adapter in 2014. Made sense the gasket had lost it's plumpness in 5+ yrs.
That's the only issue I've had. I would like a longer filter, but not sure what to replace the current one with.
1989 928 S4 5 spd - black
husker boxster is online now   Reply With Quote
Old 02-04-2020, 11:23 AM   #4
Artist, 986S tinkerer
NewArt's Avatar
Maybe in the beginning my LN adaptor wasn't on tight enough but it would spin off when I removed the filter. Doesn't seem to do that the last couple of times but I do get some occasional drips. I'll look into the new gasket thing.
Old 02-04-2020, 12:50 PM   #5
So far so good on mine.
Hadn't heard about the potential to develop the need for a gasket replacement set. I got my spin-on adapter in 2009! No leaks to date, but I guess I better keep an eye on it at this point. (This car has been amazing: since getting it in 2006 I've never seen so much as a drop of oil on the floor where it's parked.)
Actually did have one problem, but it wasn't the fault of the SPOFA. Had some work done at a place I've used before and, being in need of an oil change and feeling lazy/too busy, asked them to change the oil/filter for me. Well, whoever did it cranked the ever lovin' hell out of the filter when they put the new one on. Next time I went to do the same task, the adapter came off with the filter, something that had never happened to me before. (I had done all the oil changes since the SPOFA.) I then spent like an hour trying to get them apart—even enlisted the help of a guy working at Advanced Auto. The old filter was thoroughly mangled by the time we got them separated.
Old 02-06-2020, 07:03 PM   #6
I upgraded to the oil filter adapter and have not looked back. I have a oil filter cutter that makes looking a media a sinch. I run a longer K&N Filter... fits great and plenty of room/ clearance to ground below. Filter is still higher than AL oil pan. I run the HP-2006. You can find them everywhere- even at Wally World. Love the wrench off feature as well... run K&N oil features on all of my vehicles for this very reason.
HP-1007 (Stock/ Napa size that comes with adapter)
Height: 3.74 in (95 mm)
Outside Diameter: 2.98 in (76 mm)
Thread Inside Diameter: 0.81
Thread Number: 16.00000
PSI Relief Valve: None
Anti Drain Back Valve: Yes
Style: Canister
Bypass Valve: No
Weight: 0.4 lb (0.2 kg)
The one I use is:
HP-2006
Height: 4.78 in (121 mm)
Outside Diameter: 2.99 in (76 mm)
Style: Canister
Bypass Valve: No
Weight: 0.8 lb (0.3 kg)
aparke4 is offline   Reply With Quote
Old 02-07-2020, 10:20 PM   #7
Great gadget. Why didn't the factory do this? What possible advantage is there to the OEM plastic cup design ?
old911doc is online now   Reply With Quote
Old 02-08-2020, 05:40 AM   #8
Who's askin'?
maytag's Avatar
Yeah, I ordered mine yesterday, based on reading I did because of this thread.
Oh, there are some VERY entertaining threads on this forum regarding this mod. And it's fun to see that personalities don't change much in 8 year's time, Haha.
I see below a comment from az986s about remote mounting it. I'd sure love to know more about THAT. AZ?
Old 02-16-2020, 06:31 PM   #9
jaykay's Avatar
All good with mine.....I also have a filter magnet slapped on there
986 00S
Old 02-19-2020, 08:16 AM   #10
Good call- i bought a oil cooler filter off amazon and thought it might actually help some with the filter being exposed to moving air under the car but i dont think the oil will be in the filter long enough to actually cool... I would rather have the filter mag as a bigger brother to my mishimoto mag drain plug.
Here is the cooler for reference:
https://www.amazon.com/Oil-Filter-Engine-Aluminum-Accessory/dp/B07VFJC5YW/ref=pd_sbs_263_t_0/132-6496509-7857045?_encoding=UTF8&pd_rd_i=B07VFJC5YW&pd_rd_r=d7a1d95a-6ec1-4fbd-8e6d-9eb182859bbc&pd_rd_w=1YfDp&pd_rd_wg=7dRVV&pf_rd_p=5cfcfe89-300f-47d2-b1ad-a4e27203a02a&pf_rd_r=SAAB83KS9717FBQGE9RF&refRID=SAAB83KS9717FBQGE9RF&th=1
Old 02-19-2020, 08:50 AM   #11
BYprodriver's Avatar
Just like all the other new rules for the environment, less Hazmat going to garbage dumps. That's why they want you to change oil at 15,000 miles.
I have had my SOF adapter since 2006 (bought from Jake Raby) along with the magnetic drain plug. Never any issues with either part & I had to R&R the SOF when the case went to LN in 2009.
Old 02-21-2020, 06:26 PM   #12
jaykay's Avatar
Very neat idea / product but as you mention time / volume is not on side with this arrangement.....thanks for the interesting post though
986 00S
Old 02-27-2020, 03:30 AM   #13
I’ve never had an issue with the SOF, installed 2009, but the first magnetic drain plug developed a pinhole about 2 years ago and leaked a few drops a day. I had a hard time believing that was the source of the oil but replacing it resolved the leak.
2000 Black 996 Aero, 2001 Forest Green Boxster S, 94 Midnight Blue 968 Cab, 1980 Pongee Beige 911SC Weissach Edition, 2004 BMW R1200CLC
ymkmkrz is offline   Reply With Quote
Old 02-27-2020, 05:33 AM   #14
I've had mine for a few years with a magnetic drain plug. No issues and less mess. Put one on my 981 as well.
2022 PCA Zone 7 Autocross Chair
2001 Boxster 986 (base) #414
-PCA GGR: Class Champion AX12 '18, '19, '20; CC06 '21; CC05 '22; PAX 5th '19, 3rd '20, '21, & '22
-PCA Zone 7: Class Champion P14 '18, '19; P02 '20; P-03 '22; PAX Champion '20 & '21
BrantyB is offline   Reply With Quote
