Old 02-18-2018, 02:44 PM   #21
Originally Posted by Boxstard View Post
Does this poorly designed factory bolt take any part of the bearing failure?
Yes. Sometimes when the bolt fails, the IMS bearing can move off axis, timing chain(s) jump, and you get piston to valve contact related failure. The IMS bearing itself is still relatively OK except for the bolt failure. Other times, the bearing itself is tearing up, possibly causing the bolt failure; so it can go either way.
