Old 08-11-2020, 04:05 PM   #1
Drop Link bolt stuck and I'm out of ideas
Rear drop link on passenger side. The smooth bolt through the wheel carrier is beyond stuck. I removed the socket from the ball side and I can get an impact on the nut type section below the ball. The bolt will turn with an impact wrench on it. It will not budge to move out. I've tried heat, cans of liquid wrench, wd 40, hammer, bigger hammer, biggerer hammer, tried getting a gear puller on it.
No joy. I am completely out of luck ....... it's now day 4......
2ata is offline   Reply With Quote
Old 08-11-2020, 04:26 PM   #2
piper6909's Avatar
It looks like this is not uncommon, although I haven't tried on mine. You said it turns with an impact? Does the bolt spin with the nut? If so you may have to cut it off on the nut side or try to get a wrench or visegrips on the other side to hold it.
Someone else had a similar issue, but he was able to get the nut off, the bolt was stuck:
http://986forum.com/forums/boxster-general-discussions/47796-rear-drop-links-help.html
2010 Subaru Forester
Old 08-11-2020, 04:46 PM   #3
Nut came off from the thread end with no issue. It's literally the smooth bolt through the wheel carrier where it is stuck. I previously confirmed that the entire bolt turns with the impact wrench.
Old 08-11-2020, 05:13 PM   #4
piper6909's Avatar
See if one of there will fit over it:
https://www.harborfreight.com/3-4-quarter-inch-forged-ball-joint-separator-99849.html
If the bolt turns, all you should need some pressure to push it out while you hit it with the impact. The problem you're having now is that while the impact turns it, there's no pressure to pull it out. Actually the impact is probably applying force that keeps it in. You need pressure from the other side to push it out. Maybe this tool will help. It may even push it out without the impact.
Old 08-11-2020, 06:23 PM   #5
Qingdao's Avatar
Cut off wheel.
'98 PP13B powered "RX986"
Qingdao is offline   Reply With Quote
Old 08-11-2020, 06:45 PM   #6
piper6909's Avatar
Originally Posted by Qingdao View Post
Cut off wheel.
That would help if the nut is stuck on the bolt and the bolt free-spins in the housing. He has the opposite problem. The nut is off. The bolt is stuck in the housing. He'll need to push the bolt out while turning it with the impact.
Old 08-11-2020, 07:12 PM   #7
Qingdao's Avatar
Ah, I see he can't get the bolt that affixes the link to the strut/spindle.
Use a ball joint press or a c-clamp. Put a socket on the one side to give an area of recess and a punch on the other end to drive it through.
Air hammer helps.
Old 08-11-2020, 07:19 PM   #8
Will there be cake?
tonythetiger's Avatar
I had one stuck once and used my torch, red hot then cooled with ice, two cycles. Came right out when I twisted with a wrench.
Old 08-11-2020, 07:25 PM   #9
piper6909's Avatar
Air hammer helps.
I suggested the ball joint press, but I like the C-clamp and socket idea better!
Old 08-11-2020, 07:34 PM   #10
Qingdao's Avatar
Sorry... I miss links sometimes.
If the OP loosens the toe control arm link (??? Correct term??) and the CV axle he'll be able to twist the strut. That'll give him a better angle on the bolt so he can strike it; like hitting a home run.
Old 08-11-2020, 09:24 PM   #11
Lots of PB Blaster, and get it spinning with the impact gun. Spray again, and spin opposite direction. Once you spin it a few times in both directions, the corrosion should loosen up and you can back it out........ both of my rear shocks had this problem...... 20 years in New England.....
-Eric
Eric-986 is offline   Reply With Quote
Old 08-12-2020, 04:05 AM   #12
I'll have to try the C clamp this evening.
Heat, cool, and lube were all a no go in any combination. Impact wrench and a Hulk smash BFH when applied together offered nothing.
Old 08-12-2020, 10:24 AM   #13
morgal48's Avatar
If I understand your issue, have you jacked the wheel carrier up, or let it down, at the LCA ball joint to change the angle? It could be bound up (binded?) due to the non alignment of the holes at the other end where the offending bolt is. The bolt could spin, but not release.
2000 Boxster S
2010 Volvo XC60
2011 GMC Denali HD 6.6L (sold)
2008 Cayenne S (sold)
1989 Targa (sold)
morgal48 is offline   Reply With Quote
Old 08-12-2020, 11:02 AM   #14
The corrosion builds up on the middle of the bolt, keeping it from sliding out...... I had the best luck with the impact gun spinning the bolt to "grind" off the corrosion.... it did take a little while though.
-Eric
99 986
09 Cayman S
Old 08-12-2020, 11:05 AM   #15
Yes I have tried jacking it up, down, every which way without any advantage.
Old 08-12-2020, 03:59 PM   #16
Get some ATF and some Acetone.
Mix 50/50.
shake the hell out of it. (each time you use it) and saturate the bolt as often as you can over a 24 hour period.
get a muffler gun. (Air operated impact gun) fitted with a punch.
Cheap at Harbor freight.
You should have very little problem driving it out with a muffler gun.
Especially since you can turn it.
Old 11-30-2024, 08:09 AM   #17
Bit of a thread resurrection here. I have had a titanic battle with removal of one of the front drop links on my 986S.Finally removed it this morning after numerous attempts, over several weeks. During that time I purchased an impact gun, heat gun, large hammer, decent hack saw and penetrating oil. All these new items played a part but the impact gun finally freed the stuck bolt. I then found it would turn freely but still not come out. Finally I managed. Trouble is now, I cannot get the new bolt in the hole, through the steering knuckle. There is a kind of metal plate obstructing the hole, roughly in the middle. I guess this was why the old bolt would not finally come out. I have pictures but it would not let me post then. Is my problem due to the angle it is jacked up at? I have it level at the front, jacked up on each side, both wheels off. I also tried with an extra small jack under the hub. Any ideas how to resolve this? Thanks in advance.
El 3.2S is offline   Reply With Quote
Old 11-30-2024, 10:06 PM   #18
Metal plate you mention is most likely the shock absorber connection point that the bolt has to go thr. Try to push the schock body up or down to align the metal plate exactly right location to allow the bolt to go thru.
Here yuo can see the image of the metal plate on the shock absorber I mention above:
https://www.pelicanparts.com/More_Info/98633305131.htm?pn=986-333-051-31-M1012&SVSVSI=784&DID=5453
Also, place some anti seize paste (like copper paste etc.) on to the center section of the bolt, so it won't seize there again.
2001 996 C2 Manual
Old 12-01-2024, 03:29 AM   #19
Thanks for the reply. Yes, what you describe is exactly what is causing the problem. Not getting any meaningful movement in the shock though. Maybe this is due to the part which is causing the obstruction, being badly out of shape now? I have tried prising it up, down or sideways by using a large screwdriver in the hole. Have resorted to trying to file the offending part away, but my file does not seem up to the job. I have done many jobs successfully on my Boxster but this has been my first foray into the world of suspension, pretty sure it will be my last too!
Definitely going with the copper slip, if I ever get the new part fitted.
Old 12-01-2024, 04:02 AM   #20
If not done yet, spary some wd-40 etc penetrating oil to the connection between shock absorber and hub in a way that it flows down between those two parts and leave it for a while and then try again.
I'd advice not to pry the hub open from the slit where shock absorber metal plate goes in to the hub, since I have read that few people has cracked the hub doing that.
2001 996 C2 Manual
