Old 05-11-2007, 12:32 PM   #1
May have screwed up my car?
Okay, I'm not sure if I screwed up my car or not, but I never noticed my car doing this before. Let me start at the begining. Last week I was doing some drag racing (at the track) and was doing some really good launches with my car. At the the end of the day I noticed a burning smell, like the clutch or could have been a rubber smell, like the Serantine Belt. Definately was not the tires.
This week while driving, I noticed when I am accelerating and want to merge or get more pick up by punching the gas, the car engine seems to rev high before I feel any pick up. It's like a few seconds of a delay. W.T.F. Is it possible that my clutch is going or slipping? How can someone tell if it is slipping. Car was already in gear when this happened and the clutch was not pressed at all. Could it be that I streched the Belt or burnt a flat spot onto it? It feels as if the belt is slipping more than anything, but I'm not sure if that is possible because our Boxsters have the Belt Pulley Tensioner. It almost feels like the cars fuel injection is off a bit with the cars pick up, i.e. acceleration. Could I have screwed up the timing? No check engine lights have come on. I'm having the belt replaced next week as part of it's regular maintenance and hope this will fix the problem, but I am not sure. It's also speratic, and some times does not do it at all. Now I'm worried.
porsche986spyder is offline   Reply With Quote
Old 05-11-2007, 12:35 PM   #2
07 Carrera S Cab
Boxtaboy's Avatar
Nope...not the serpentine belt. You have fried your clutch. That is the clutch slipping. New clutch time. Sorry.
And the slipping will only get worse until it totally dies on you, and you won't be able to move the car. The slipping will basically get to the point where you shift into the gear, step on the gas, and you will see the revs go up, but the car won't move anymore. Get it to a shop and have the clutch replaced, and don't use the Boxster as a drag racer anymore...it's not meant for that kinda work.
Old 05-11-2007, 12:37 PM   #3
It sounds like the clutch has gone south. To check, try this: Run the car through the gears to 4th or 5th. At cruising speed, try to accelerate hard. If the car revs but doesn't move (or hesitates before pulling, as you say), you're going to need a clutch.
EDIT: Ha! Boxtaboy beat me to it.
http://i84.photobucket.com/albums/k2...izzlysmall.jpg
'97 986
Cheating Death on 19" Wheels
...no catastrophic engine failure ...yet
Grizzly is offline   Reply With Quote
Old 05-11-2007, 12:43 PM   #4
That's what it does. Sounds like I burnt that sucker. That's it, no more racing for me. Would an extended warranty cover this, or is that considered regular ware-n-tare and does not cover the clutch?
Old 05-11-2007, 12:43 PM   #5
O yea cluch is gone...i test drove one boxster and thats what it was doing, in 2rd the car wouldnt even move and there was plenty of smoke comming through side vents, that one whas completely gone
blueillusion97 is offline   Reply With Quote
Old 05-11-2007, 12:48 PM   #6
07 Carrera S Cab
Boxtaboy's Avatar
Not sure if your extended warranty would cover a wear item like a clutch. New clutch will cost you about $1500 (parts/labor).
Old 05-11-2007, 12:49 PM   #7
Okay, stupid question about the clutch and warranty. Don't know what I was thinking. No way is that covered.
Old 05-11-2007, 12:52 PM   #8
Anyone know of the cheapest place to get an O.E.M. clutch. Or anyone know of a better racing one, maybe a high performance clutch that I can upgrade to?
Old 05-11-2007, 12:52 PM   #9
Hopefully this will save you some money;
http://buyclutch.com/ (give them a call or email them,their site isn't working correctly)
You may want to check and see what parts are required for the clutch replacement to ensure that those 3 parts are all that is needed to replace the clutch.
Old 05-11-2007, 01:38 PM   #10
So what times/speeds were you posting?
conradtan is offline   Reply With Quote
Old 05-11-2007, 02:51 PM   #11
deliriousga's Avatar
http://www.****************************************************.com/porscheatcost.php has genuine kits for great prices.
1966 Wife White/Brown Top
Old 05-12-2007, 05:20 AM   #12
Def your clutch. I'd avoid the dealer and have a good indy shop do the work. While you're there, have a look at/ replace the RMS.
If you want to spend time at the drag strip, get a drag car!
Patrick
Old 05-12-2007, 09:08 AM   #13
+10 on the clutch.
The clutch in my old Toyota Tacoma wore out, and it was driveable, but in just about any gear, if I punched it, the engine would rev higher, but acceleration was not there.
Had the clutch changed, and the clutch lining was COMPLETELY gone.
If this happens, I'd surmise it could damage the flywheel surface, but it didn't cause any problems in my Toyota.
If I were you, I'd look into replacing the clutch soon. I wouldn't worry too much about the flywheel, they can check it when the transmission is off. The clutch is a consumable part - they'll wear out sooner or later.
Oh, and remember that smell. Nothing smells like a clutch burning!
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
Old 05-12-2007, 10:05 AM   #14
leeedwards's Avatar
I just replaced my clutch, Dealer in Fremont Ca. quoted $2000. including RMS replacement. I found independent shop in Oakland Ca. who did the job for $1400. So shop around.
leeedwards is offline   Reply With Quote
Old 05-14-2007, 06:27 AM   #15
Thanks for all the advice. I'm going to replace the complete clutch and the RMS while they have the whole thing out. Kill 2 birds with one stone I figure. Found a shop I use that will do it all for $950.00
Old 05-14-2007, 06:34 AM   #16
drag racing? lol
btw, what time did you get? was this a 1/4 mile?
just go out and do some autoX man
my cardomain/pictures page
Old 05-14-2007, 09:06 AM   #17
JAAY's Avatar
950 is a good price. You are going to need a new flywheel too. your old one is going to be terribly heat checked. New flywheel = $900.00
I just did the whole thing with new seals. 2000.00
J
Old 05-14-2007, 09:57 AM   #18
J
It's $950.00 for the labor and $15.00 for the RMS part, $377.00 for the complete clutch kit. I'm hoping I won't need a new flywheel. We'll see.
Old 05-14-2007, 10:09 AM   #19
TriGem2k's Avatar
Send a message via AIM to TriGem2k
I had dealer do the clutch for me, Parts & Labor $1400... You should check with your local dealer. Sounds like the indy shop is going to save you about $80. That's not worth it in my opinion.
-GT3 Front Bumper w/ Lip
-Side Skirts
-Gemballa Exhuast and Cats
-O.Z. Racing 18" Wheels
--18X8.5Front 18X10 Rears
-5mm Rear Spacers
-Porsche Door Sills
-H&R Springs
-Powerflow Intake
-B&M Short Shifter
-Focal Polyglass 165VR3
-Alpine PDX 5 Amp
-Audio Controld DQXS (DSP)
TriGem2k is offline   Reply With Quote
Old 05-14-2007, 10:12 AM   #20
Steelership wanted 1,200 just for labor alone! Boardwalk Porsche, Plano Tx.
