Old 07-12-2015, 03:27 PM   #1
new... just bought. '00 S
2000 S, just hit 44k on the odometer.
Has a few issues i need to address. Someone stole the ash tray out of it (but left my DSLR and a brand new head unit that was sitting in the car.)
Drives well. It'll need tires soon :ah:
Never have really been into boxsters, or even porsches in general. I've mostly worked on turbo 4 applications. Always was turned off by the "low" power levels, but this car was a dream to drive from day one (have had it for just over a week now)
The top doesn't work right, the window is messed up, the thing that the top clamps too has an issue with the screws stripping out. I messed something up when doing a single-DIN install (preouts going to stock amp)... I didn't know about the wire that activates the immobilizer... but now that i've straightened that out, I can't get the car to lock properly and the keyfob just doesn't do anything (single beep if i lock by hand, no blinking red light on dash anymore... i'm not sure. My wing also isn't going up by itself right now. no idea what happened. the wing light comes on and stays on until i put the car into a forward gear and start moving.
Needs ignition switch, i'll do it this week.
So basically every little interior issue Boxsters have, I still need to take care of!
Cosmetically it's super nice other than the back window. It just has some kind of exhaust on it. I'm not sure what it is, but it's deep and really subtle. I like it. Not too loud.
My only plans right now are to get everything back to normal, I'm having a friend do a nice detail on it this week... Eventually I would like to get a set of wheels. I kind of like how those forgestar F14 wheels look, but I am still a little skeptical of them when it comes to quality.
The car is a blast, having more fun without brutal acceleration that i'm used to... nice to just cruise and wear the tires out going around the corners. Never thought I'd like something with just 250hp THIS much!
Got a great deal on it. Friend was moving across the country and offered me the car for slightly less than what a dealership was going to give him.... once i drove it, it was a no brainer!
Looking forward to putting some more miles on it. I like to put miles on my cars. I don't like having the roof up, ever. I'm not sure how long the stock clutch typically holds up, but I intend on doing something to prevent IMS failure when i have to do the clutch. Maybe sooner. I feel like I'm kind of gambling by not just doing it, but also just don't have the desire to tear apart the car right now.
One question (that i could probably look up) ... are there usually tell-tale signs that IMS failure is imminent or is it something that's usually just instant and catastrophic?
I'd rather not have a blown up boxster.... been keeeping an eye on the LS swaps. I was planning on swapping a mildly built 5.3 LS engine into something at some point... I'd like to see more examples and more feedback on that swap at some point... but the car is more than enough right now to have a LOT of fun with. I'd rather not HAVE to pull an engine out
hazardc is offline   Reply With Quote
Old 07-12-2015, 03:29 PM   #2
In my ramble, i forgot to attach the picture.
Here she is! Looks like pretty much every other silver boxster
Old 07-12-2015, 04:57 PM   #3
Yeah, I've done that.
leftfield6's Avatar
Welcome aboard! She looks nice. Beautiful color.
Get one of the non-ashtray inserts to replace it. Looks better IMHO
Sumitomos on mine, are just about the least expensive but decent quality tire
I had the same issue with the dome light/header assembly being loose. I wound up putting two nutserts into the metal frame, now it is rock solid.
The spoiler dash light is the correct behavior. It should come on and stay until you begin to move forward and then go out. How do you know it's not going up when you hit 70? I didn't think mine was working, but I used my video on my phone to chek it out. Basically got up to about 60 with th top down, hit record, held the phone up pointed it the rear deck and hot the accelerator. Sure enough when I hit 70 it came up. When I slowed it dropped.
1999 Boxster, Tiptronic, Hard Top, Arctic Silver with Boxster Red Interior
leftfield6 is offline   Reply With Quote
Old 07-13-2015, 11:34 AM   #4
Welcome to our Boxster world. Like you I didn't know what I was missing all these years. Such fun cars! May I suggest at minimum a oil/filter replacement and cut away filter to chk for medal debri. You may also want to invest in a magnetic drain plug.
Lapister is offline   Reply With Quote
Old 07-14-2015, 09:39 AM   #5
Great looking car. I have an 00 Boxster myself that I'm throwing a 5.3L in. Hopefully, I will be able to start it next week.
martsink is offline   Reply With Quote
Old 07-14-2015, 09:43 AM   #6
I recommend putting as little money into the car as possible. Live with the little crap that bugs you but doesn't hamper safety.
You'll never get anywhere near what you paid for it or what you'll put into it when you get rid of it.
Which is why I wouldn't throw another $15k or more down the black hole to upgrade the motor to an LS if she blows. I'll sell it as a roller and get on with my life.
It's a blast to drive if you have twisty roads nearby though. Absolutely perfect balance for twisties!!!!!!!
Old 07-14-2015, 10:41 AM   #7
Giller's Avatar
Just my opinion - but don't skimp on the tires. Get a decent set. These are performance cars and the tires you put on can make a noticeable difference. Not to say you have to buy the most expensive, but make sure they are speed rated and a good brand. Reduced noise, better grip, better cornering, smoother ride....
And at 15 years old - what, if anything has been done to the suspension and motor mount? While the km's are low - time can still take a toll and again, the whole point of these cars is about how they drive. Up to date suspension and motor mounts can make a world of difference.
Just a couple thoughts to add to your projects list.
And don't forget to de-amber!!
Old 07-14-2015, 12:14 PM   #8
Refreshing the suspension and motor mount = $2500 or more, and that's just for parts!!
Old 07-14-2015, 12:45 PM   #9
Giller's Avatar
Yeah, it's not cheap.....but it can (depending on current condition) make a big difference in how the car rides and drives.
Very few things on these cars are cheap. But sometimes it's worth the money. Suspension to me is a big part of the car's handling and a suspension in good nick makes the car feel so much better. IMO. YMMV.
Old 08-22-2015, 09:13 AM   #10
On reading up, the 2000my don't seem to suffer IMS failure as much as later model cars. Which I hope is true as I have '00 S as well.
ton246 is offline   Reply With Quote
Old 08-22-2015, 11:32 AM   #11
On the slippery slope
JayG's Avatar
I have an extra ashtray in excellent condition
Make offer
2004 996 Targa Tip
Instructor - San Diego region
Old 08-23-2015, 04:36 AM   #12
Nice! Congratulations.
1999 Silver Boxster
www.mulcahey.com
https://www.instagram.com/garymulcahey/
GaryMulcahey is offline   Reply With Quote
Old 08-25-2015, 03:28 PM   #13
Joeyshef's Avatar
Stealing the ashtray must be a "thing" mine was also taken. There are some ashtray delete kits out there that look good.
Joeyshef is offline   Reply With Quote
Old 03-21-2016, 08:46 PM   #14
I am about to find out... The car felt solid as can be most of last year, but I have noticed a little "shift" in the rear that I can only attribute to a failing mount.
Right now I am trying to determine what tires to go with (balance of performance and not burning them up quickly.... prefer low road noise, it does see some miles, and I would rather just keep the daily-driver balance to it)
Other than that I am going to do all the usual tuneup crap soon, seeking out a new top and some misc parts... going to go over all the suspension components to see what's looking hot and what's looking not.. .The car was obviously well taken care of before I got it, but I have no records -- meaning I have to look at it as if nothing was ever done.
This might be a wallet-burning spring, but I have been trying to prepare for it as best as possible.
Going to be scouring the forums for all the little "projects"
HTML code is Off
