10-17-2020, 09:58 AM
#1
Oil drain pan and filter wrench
Hey I’m in the market for a new oil drain pan and filter wrench for a NAPA Gold 1042 what do you guys use? I am deep sumped so I’ll have about 10 1/2 L coming out. I like the look of the combined container and pan style but it looks like it’s going to splash all over the place when used. what are your thoughts?
986 00S
10-17-2020, 11:09 AM
#2
oil drain pan
10-17-2020, 02:15 PM
#3
That looks like the ticket how tall is it? I am really lowered....and I will be on ramps
986 00S
10-18-2020, 04:16 AM
#4
1998 Boxster Silver/Red
I use the same tub as Keith. Works great. It'll be fine under the car on ramps.
1998 Porsche Boxster
10-18-2020, 04:23 AM
#5
A Porsche Guy
I use the Hopkins FloTool 42003MI 16-Quart Drain Container purchased at Walmart for under $15 at the time. I use a shipping box, perfect size in my case, to put the oil container in so I can drag it without wearing the plastic down and prevent any excess spills to the floor. It's been working great for the past few years. I do a few oil changes before dumping it at the local Autozone. I use rhino ramps and there's enough room.
Looks like it's on sale
https://www.walmart.com/ip/FloTool-42003MI-Drain-Container-16-quart/44580714
10-18-2020, 04:38 AM
#6
I have the same one as Keith, works great. I bought it at princess auto after I had an accident with my 10 liter one, I think it was under $20.00 including tax.
10-18-2020, 07:22 AM
#8
Motorist & Coffee Drinker
I'm seriously considering an oil extractor pump for my TDI Touareg (Tow Pig). Does anyone use an extractor on their 986? Seems like a clean easy way to do oil changes without pulling the plug.
Any recommendations for an extractor? "Mityvac 7201 Fluid Evacuator Plus" is what I'm thinking.
10-18-2020, 08:05 AM
#9
I have a recommendation: DO NOT USE AN EXTRACTOR, change the oil the way it was designed to be changed.
Over the years, we have had numerous Porsche's flat bedded to the shop because someone got the tube down into the sump, and then could not get it out. There are just too many edged surfaces that can catch and trap an extraction tube, making it impossible to pull out from the top. When that happens, the sump cover has to come off and the tube pulled out from the bottom. Bad idea.
10-18-2020, 10:07 AM
#11
2022 PCA Zone 7 Autocross Chair
2001 Boxster 986 (base) #414
-PCA GGR: Class Champion AX12 '18, '19, '20; CC06 '21; CC05 '22; PAX 5th '19, 3rd '20, '21, & '22
-PCA Zone 7: Class Champion P14 '18, '19; P02 '20; P-03 '22; PAX Champion '20 & '21
10-20-2020, 06:57 PM
#12
Yeah that what thought as well, while 8 inches is a very good number in certain regimes, catching splashing hot oil is another ball park
I may give it a go as the other features are good......wheels, storage and secure transport.
I went out and bought a similar wrench on Amazon. Thanks for the feedback.
986 00S
10-21-2020, 10:58 AM
#13
20 gal mixing tub from HD $14 bucks or so. Use this and/or place the others shown inside of this
10-21-2020, 06:02 PM
#14
Nice idea!
986 00S
10-28-2020, 01:38 PM
#16
On the slippery slope
same one I have, works great!
2004 996 Targa Tip
Instructor - San Diego region
10-29-2020, 02:02 PM
#17
Originally Posted by rfuerst911sc
Is 8" dia opening too small in your opinion? Just came in today and need to make a call.
986 00S
10-29-2020, 02:07 PM
#18
I went for the ramps and I am way too lowered for them .....in a bit of a bind with only my race jack on hand to do a staged lift up on to stands using rear suspension mounting points. It will be a process. Hopeful the oil will still be warm once up
986 00S
10-30-2020, 09:01 AM
#19
You can always run the car on ramps to warm it up.
In any case, it takes a bit of time for the engine to fully cool down
Try a small 2x8 in front of the ramp to raise the car a little to get on the ramps
2004 996 Targa Tip
10-30-2020, 12:28 PM
#20
I use the same one. I can do oil changes on the Box and my BMW then seal it up for a single trip to dump at Advanced Auto.
98 Arena Red 986
