Old 06-21-2020, 07:37 PM   #1
Who's askin'?
maytag's Avatar
Could y'all walk me through the evap system?
Hey y'all!
In my quest to get this car through emissions inspection, I've now solved the o2 sensor issue I was having.
The only persisting issue now is an evap issue. Code po446, which i know can mean several things, but accompanying symptoms include strong gas odor and difficulty starting the first time after filling the tank.
Last weekend I popped-off the inner fender liner (front right) and unhooked the lines from all the various crap in there. I blew compressed air through the various hoses and didn't encounter any blockages that I could detect.
So the problem I have right now, is that I'm vague on what each item is, and what it is supposed to do, and when.
I searched this forum and Googled, and most discussions center around the purge valve under the intake plenum, left side. So with a test light, I've confirmed voltage at the valve..... but i don't know WHEN it's supposed to have voltage, or whether that voltage opens or closes the valve, so i can't really test the valve.
I could use a basic flowchart-type narrative of the entire evap system. Can y'all help me? Or steer me somewhere where it's already laid-out for me?
Thank you!
Old 06-22-2020, 06:40 AM   #2
Old 06-22-2020, 09:51 AM   #3
Who's askin'?
maytag's Avatar
Thank you, JFP. you're always good for the details, man!
I saw this diagram previously, and it's somewhat useful (though I'll confess that the stuff under the fender liner doesn't look a LOT like that, haha).
But what I could really use to accompany this diagram, is a flow-chart narrative:
"when xyz happens, valve A opens and releases gasses to CDE"
and "under these conditions, the purge valve should get voltage, which opens/closes the valve....."
etc etc.
Y'know? I can't tell which parts aren't working the way they should, because I cant ell which part is supposed to do what, or when it's supposed to do it.
I'm afraid it's all too very-much like plumbing. And I really SUCK at plumbing.
Old 06-22-2020, 10:44 AM   #4
OK, P0446 indicates that the EVAP canister shutoff valve is operating below flow limits. Normally this is caused by the purge air line (#3 in diagram) being blocked. Normally, this can be fixed by disconnecting the line at both ends and blowing compressed air thru it to clear it. If this line is clear, the only other possibility is that the flow thru the EVAP canister carbon bed is blocked, which requires replacing the canister.
Old 06-22-2020, 05:17 PM   #5
Who's askin'?
maytag's Avatar
Thank you, JFP!
Before I hit "buy" on a replacement canister: no chance I've got a problem at the purge valve? It's definitely the canister? (I've blown the lines already)
Old 06-22-2020, 09:58 PM   #6
I would check the valve first, it can also get plugged or become inoperative.
Old 06-23-2020, 05:46 AM   #7
78F350's Avatar
Meanwhile, I'm replacing the fuel line vent valve on a car that spits out gas when you try to fill it. I hope you don't mind if I add this here for future reference to the evap system for others who end up here.
This tech article is on the 996 section of the PelicanParts DIYs, but it is identical to the system on my '01 986:
https://www.pelicanparts.com/techarticles/Porsche-996-997-Carrera/106-FUEL-Replacing_Your_Fuel_Line_Vent_Valve/106-FUEL-Replacing_Your_Fuel_Line_Vent_Valve.htm
Video included on that page:
Maytag - I'm going to be pulling the evap system out of a parts car (low flood damage). Let me know if you want any cheap 'probably good' parts from an '01.
Old 06-23-2020, 10:56 AM   #8
Who's askin'?
maytag's Avatar
That's what I'd like to do.... but I'm too fuzzy still. I assume the valve is holding vacuum from the intake, right? Or is it holding pressure from the tank / evap?
And should it be "open" or "Closed" (flowing either vacuum or pressure) when voltage is applied?
And under what circumstances is that voltage applied / not applied?
That sounds very interesting to me. ABSOLUTELY. I'd say let's think about the canister & the purge valve and whatever else makes sense right there.
Old 06-23-2020, 11:20 AM   #9
I really is not important if the valve faces pressure or vacuum, only that it works when power is applied, and that when it is open, there is flow through it.
The EVAP system is supposed to absorb (actually adsorb, but that is another science lesson) hydrocarbon vapor accumulating in the fuel tank onto the activated charcoal in the cannister; under the correct operating conditions (warm engine, high intake system vacuum), the purge line opens, sweeping air thru the cannister media and pulling the hydrocarbons into the intake to be burned rather than released to the atmosphere as they were with the vents on older fuel systems. The the lines need to be clear, and the valves have to open on command from the DME to get rid of the vapors.
Old 06-23-2020, 12:00 PM   #10
Who's askin'?
maytag's Avatar
aaaahhhhhh this is good stuff, JFP! I understood, of course, the 100k foot view of what it is supposed to do, but not the mechanics of it.
So here's where I'm at then: Cold engine, I have voltage at the purge valve. didn't bother to pull it out yet to check it, because it's a PITA to get to, and I didn't have any way of knowing if voltage should be opening or closing it.
So SHOULD I have voltage when the engine is cold? And if the answer is yes, then I can assume the valve is normally-open, and the voltage holds it closed. Yes?
OR - do I have a problem in the control someplace, indicated by the presence of voltage when cold?
Old 06-23-2020, 01:25 PM   #11
When you say you have voltage at the purge valve, is that key on or off? And where is the valve you are testing, in the wheel well or under the intake manifold?
Old 06-23-2020, 04:43 PM   #12
Who's askin'?
maytag's Avatar
Details! that is with the key on, and it's the valve under the intake. Engine off and cold.
Old 06-23-2020, 06:41 PM   #13
That valve is under intake level vacuum and connected to the intake near the throttle body (item#20):
It should show 12V with the key on and be open under electrical power.
Old 06-24-2020, 09:18 AM   #14
Who's askin'?
maytag's Avatar
there's the nugget I was looking for!
But your question makes me wonder: is there ANOTHER purge valve somewhere that you thought I might've been referring to? Should I be checking a DIFFERENT valve?
Old 06-24-2020, 09:24 AM   #15
The operating purge valve at the cannister (item #7 in the top drawing).
Old 11-23-2022, 08:55 AM   #16
Sorry to resurrect an old thread, but - I had p0446 , then purged the lines, and now have p0447. Not as many details about this code but seems like the valve under intake has gone bad. Any consensus on this?
chromecarz00 is offline   Reply With Quote
Old 11-23-2022, 09:12 AM   #17
P0447 is the code for an open circuit on the EVAP canister shut off valve at the EVAP canister. Wiring fault or it is disconnected.
Old 12-29-2022, 12:21 PM   #18
Hello everyone,
Since this thread has been resurrected already, I'll chime in with my EVAP issue:
On my 2002 Boxster base, I am now consistently getting a po442 code which apparently is indicative of a minor leak in the EVAP system.
During a prior troubleshooting attempt around 2 years ago I vacuum checked all air connections on or around the charcoal canister.
I also vacuum tested the purge valve under the intake manifold.
This time around, due to no clear description of the Operating Purge Valve (at the filler neck) functionality and/or availability of a proper diagnostic procedure for it, I ordered a new one from my local Porsche dealer.
Now that I have removed the old one and am comparing it to the brand new unit on the bench, they appear to function exactly the same. If interested, I can provide a better description of how that vent valve operates mechanically so others might be able to fill in the blanks as far as how that functionality integrates into the overall EVAP management on the 986 Boxster.
In the meantime, I would appreciate any and all help I can get in resolving the po442 issue so I don't have to contend with it every couple of years.
TIA
seventythree is offline   Reply With Quote
