Old 06-21-2020, 07:37 PM   #1
maytag
Who's askin'?
maytag's Avatar
Could y'all walk me through the evap system?
Hey y'all!
In my quest to get this car through emissions inspection, I've now solved the o2 sensor issue I was having.
The only persisting issue now is an evap issue. Code po446, which i know can mean several things, but accompanying symptoms include strong gas odor and difficulty starting the first time after filling the tank.
Last weekend I popped-off the inner fender liner (front right) and unhooked the lines from all the various crap in there. I blew compressed air through the various hoses and didn't encounter any blockages that I could detect.
So the problem I have right now, is that I'm vague on what each item is, and what it is supposed to do, and when.
I searched this forum and Googled, and most discussions center around the purge valve under the intake plenum, left side. So with a test light, I've confirmed voltage at the valve..... but i don't know WHEN it's supposed to have voltage, or whether that voltage opens or closes the valve, so i can't really test the valve.
I could use a basic flowchart-type narrative of the entire evap system. Can y'all help me? Or steer me somewhere where it's already laid-out for me?
Thank you!
