Old 10-17-2020, 09:58 AM   #1
jaykay's Avatar
Oil drain pan and filter wrench
Hey I’m in the market for a new oil drain pan and filter wrench for a NAPA Gold 1042 what do you guys use? I am deep sumped so I’ll have about 10 1/2 L coming out. I like the look of the combined container and pan style but it looks like it’s going to splash all over the place when used. what are your thoughts?
986 00S
Old 10-17-2020, 02:15 PM   #3
jaykay's Avatar
That looks like the ticket how tall is it? I am really lowered....and I will be on ramps
986 00S
Old 10-18-2020, 04:16 AM   #4
1998 Boxster Silver/Red
I use the same tub as Keith. Works great. It'll be fine under the car on ramps.
1998 Porsche Boxster
Old 10-18-2020, 04:23 AM   #5
A Porsche Guy
1PorscheBoxster986's Avatar
I use the Hopkins FloTool 42003MI 16-Quart Drain Container purchased at Walmart for under $15 at the time. I use a shipping box, perfect size in my case, to put the oil container in so I can drag it without wearing the plastic down and prevent any excess spills to the floor. It's been working great for the past few years. I do a few oil changes before dumping it at the local Autozone. I use rhino ramps and there's enough room.
Looks like it's on sale
https://www.walmart.com/ip/FloTool-42003MI-Drain-Container-16-quart/44580714
1PorscheBoxster986 is offline   Reply With Quote
Old 10-18-2020, 04:38 AM   #6
986 Boxster's Avatar
I have the same one as Keith, works great. I bought it at princess auto after I had an accident with my 10 liter one, I think it was under $20.00 including tax.
986 Boxster is offline   Reply With Quote
Old 10-18-2020, 05:53 AM   #7
I have this:
With a splash pad (cut to fit):
https://www.amazon.com/Lisle-38780-Square-No-Splatter-Pad/dp/B002AENGOG/ref=sr_1_3?dchild=1&keywords=oil+splash+pad&qid=1603029052&sr=8-3
And am a big believer. Super easy to move the drained oil around without any worry of spilling and pouring into the used oil bottles for recycling is a snap. The splash pad ensures there won't be any issue with splatter and losing the drain plug.
2022 PCA Zone 7 Autocross Chair
2001 Boxster 986 (base) #414
-PCA GGR: Class Champion AX12 '18, '19, '20; CC06 '21; CC05 '22; PAX 5th '19, 3rd '20, '21, & '22
-PCA Zone 7: Class Champion P14 '18, '19; P02 '20; P-03 '22; PAX Champion '20 & '21
BrantyB is offline   Reply With Quote
Old 10-18-2020, 07:22 AM   #8
Motorist & Coffee Drinker
78F350's Avatar
I'm seriously considering an oil extractor pump for my TDI Touareg (Tow Pig). Does anyone use an extractor on their 986? Seems like a clean easy way to do oil changes without pulling the plug.
Any recommendations for an extractor? "Mityvac 7201 Fluid Evacuator Plus" is what I'm thinking.
Old 10-18-2020, 08:05 AM   #9
I have a recommendation: DO NOT USE AN EXTRACTOR, change the oil the way it was designed to be changed.
Over the years, we have had numerous Porsche's flat bedded to the shop because someone got the tube down into the sump, and then could not get it out. There are just too many edged surfaces that can catch and trap an extraction tube, making it impossible to pull out from the top. When that happens, the sump cover has to come off and the tube pulled out from the bottom. Bad idea.
Old 10-18-2020, 09:46 AM   #10
jaykay's Avatar
Thanks great advice guys what do we think about this: https://www.amazon.ca/Lumax-LX-1632-Black-Drainmaster-Storage/dp/B0059HJSA2?
The 8 inch opening looks a little small to me. Too small for comfort?
Any thoughts on the best 1042 filter wrench?
986 00S
Old 10-18-2020, 10:07 AM   #11
8" doesn't give a lot of wiggle room.
This is the wrench I use:
https://www.amazon.com/dp/B08GBVHTZH/ref=sspa_dk_detail_2?psc=1&pd_rd_i=B08GBVHTZH&pd_rd_w=Zfwkq&pf_rd_p=7d37a48b-2b1a-4373-8c1a-bdcc5da66be9&pd_rd_wg=IZAjq&pf_rd_r=B7MFWBTR93Z6PJK8D63B&pd_rd_r=f44c9ff1-f663-434e-b24c-e99565427eaf&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFQTUhZWkJJTENBMUcmZ W5jcnlwdGVkSWQ9QTAzMDA3MDQxNFNWQ0RBUVoxMDdQJmVuY3J 5cHRlZEFkSWQ9QTAyNDIxNTAxQTdTVzBGS0k4WVBEJndpZGdld E5hbWU9c3BfZGV0YWlsJmFjdGlvbj1jbGlja1JlZGlyZWN0JmR vTm90TG9nQ2xpY2s9dHJ1ZQ==
Old 10-20-2020, 06:57 PM   #12
jaykay's Avatar
Yeah that what thought as well, while 8 inches is a very good number in certain regimes, catching splashing hot oil is another ball park
I may give it a go as the other features are good......wheels, storage and secure transport.
I went out and bought a similar wrench on Amazon. Thanks for the feedback.
986 00S
Old 10-21-2020, 10:58 AM   #13
20 gal mixing tub from HD $14 bucks or so. Use this and/or place the others shown inside of this
mikeinmass is offline   Reply With Quote
Old 10-21-2020, 06:02 PM   #14
jaykay's Avatar
Nice idea!
986 00S
Old 10-28-2020, 07:28 AM   #15
Back when I owned several air cooled 911's and a 914/6 I quickly learned NOT to use a catch pan with the small openings .......... think Exxon Valdez . Our Boxsters do not have as much volume of oil as an air cooled 911 but I don't trust ANY container with small openings . My Boxster has an extended sump so quite a bit of oil . So does my wifes Volvo XC90 and my diesel dually pickup .
I now have a 2 post lift so I do my oil changes standing up like a human using a conventional shop oil drain rig . But I still keep two open design containers for my diesel garden tractors and similar equipment . Like this one:
https://www.amazon.ca/Neiko-20762A-2-Gallon-Portable-Drain/dp/B00JJ63MDS/ref=bmx_2/130-3297384-8870303?_encoding=UTF8&pd_rd_i=B00JJ63MDS&pd_rd_r=9b4b9aac-c843-4e67-9f0d-30c109f6d7cd&pd_rd_w=Yf0ps&pd_rd_wg=GGad8&pf_rd_p=f660ec4a-991e-41e4-ae58-c9a67945fc93&pf_rd_r=CVFAT5FHH8APYMS9VHPK&psc=1&refRID=CVFAT5FHH8APYMS9VHPK
I will let the oil cool in the drain pan and then pour into containers that I recycle at local auto parts stores . Letting it cool = less chance of burns .
rfuerst911sc is offline   Reply With Quote
Old 10-28-2020, 01:38 PM   #16
On the slippery slope
JayG's Avatar
same one I have, works great!
2004 996 Targa Tip
Instructor - San Diego region
Old 10-29-2020, 02:02 PM   #17
jaykay's Avatar
Is 8" dia opening too small in your opinion? Just came in today and need to make a call.
986 00S
Old 10-29-2020, 02:07 PM   #18
jaykay's Avatar
I went for the ramps and I am way too lowered for them .....in a bit of a bind with only my race jack on hand to do a staged lift up on to stands using rear suspension mounting points. It will be a process. Hopeful the oil will still be warm once up
986 00S
Old 10-30-2020, 09:01 AM   #19
JayG's Avatar
You can always run the car on ramps to warm it up.
In any case, it takes a bit of time for the engine to fully cool down
Try a small 2x8 in front of the ramp to raise the car a little to get on the ramps
2004 996 Targa Tip
Old 10-30-2020, 12:28 PM   #20
I use the same one. I can do oil changes on the Box and my BMW then seal it up for a single trip to dump at Advanced Auto.
98 Arena Red 986
Stroked & Blown is offline   Reply With Quote
