07-03-2020, 03:50 PM
#61
Originally Posted by JayG
Its a very slippery slope
It is, and you never get to the bottom. For example I bought an Audi V8 for it today...
2003 911 C2
NASA HPDE Instructor
07-07-2020, 07:04 PM
#62
Out with the old. Anyone need a 2.7? The Audi V8 arrives Friday (I think), 8 weeks or so until tools down and baby arrives.
2003 911 C2
07-08-2020, 07:56 AM
#63
Originally Posted by truegearhead
Thanks, I’m putting on 315/35/17 Hoosiers today, and 245s in the front. Same setup I have on my 911, I’ll eventually need a wider front tire
That's a monster tire! I bet that is going to feel good!
09-28-2020, 03:36 PM
#64
2003 911 C2
09-28-2020, 07:47 PM
#65
You got some nuts man...no one can argue that
10-04-2020, 04:33 AM
#66
Parts for the turbo build have started flowing and I’ve started the mock up. Here’s one of the two side intercooler radiators (the water cooling rad).
Air will enter here
And exit here (the gap between the outer fender and tail light
I’m a little bummed about the weight, they’re probably 25lbs a piece. I’ll have close to 100lbs in my intercooler system including the water. All in all I’m probably adding 200-250lbs to the car in engine, turbos and cooling, so far I’ve found about 40lbs in steel that I was able to remove. Hopefully I can find some more. I still need to remove the HVAC system under the dash, anyone know what that weighs?
2003 911 C2
10-04-2020, 11:30 AM
#67
That's going to be vicious. Do you think it will handle more like a 911? Really enjoying your journey.
10-04-2020, 11:56 AM
#68
Hopefully not  fortunately the engine is in the middle so adding weight to the middle of the car shouldn’t change things much, we’ll see. I’m sure the additional power will change just about everything though, in the past throttle control rarely came into play, I was either off throttle or on full throttle. The car never had enough power to need a light foot. Hopefully the 315 series Hoosier will help, the open diff on the other hand...
2003 911 C2
10-04-2020, 06:30 PM
#69
Perhaps it's time for an OS Giken LSD..?
10-05-2020, 01:51 PM
#70
I need to upgrade to a 6 speed first but that’s a great option. Not that $1,500 is cheap but I’m surprised it’s not more expensive.
2003 911 C2
10-05-2020, 03:26 PM
#71
Frankenboxster!!
10-05-2020, 06:57 PM
#72
Where did you get the radiator for the frunk? I need to upgrade mine to something like that one
Woody
10-06-2020, 12:39 AM
#73
Shapeshifting Lizard-Man
This is really sweet. Badass looking car, I'm taking notes.
Some random quations: What's the offset on your rear wheels? Any clearance issues? And I dig your frunk mount radiator. That was the origional plan on mine, but we ended up going a different route. I'm also very much considering s̶t̶e̶a̶l̶i̶n̶g̶ borrowing your widebody design.
One of these days, we need to meet up at VIR.
10-06-2020, 02:34 AM
#74
Here’s a link to the rad, you’ll need to cut a huge hole on the front of the trunk and bumper and make a hood vent (I made one out of aluminum but you could buy something off amazon I’m sure). Plumbing this thing up is no proving to be very difficult. The Boxster has two coolant hoses going forward and two back so you need to make some complex manifolds to make it work. Still a work in progress.
OzCoolingParts Pro 3 Row Core All Aluminum Radiator + 2 x 12" Fan w/Shroud Kit for 1963-1968 64 65 66 67 Chevy Bel-Air/Impala/Biscayne/Caprice, Many Chevy GM Cars https://www.amazon.com/dp/B081YTZFD2/ref=cm_sw_r_cp_api_i_WLdFFbJTZEMCJ
2003 911 C2
10-06-2020, 02:37 AM
#75
Thanks! The rear wheels are 12”s wide with the hub right in the middle of the wheel. I don’t have fitment issues but the fenders are of course not factory. The front is 8”s wider which I accomplished by extending the front suspension (I didn’t change the offset of the wheels). The rear fenders were actually really easy to make I used .125” think aluminum (super super thin). It can’t even support itself unless it’s bolted down, but once’s secured its rock solid.
2003 911 C2
10-06-2020, 05:48 AM
#76
10-06-2020, 01:46 PM
#77
Do you really need the fans for the middle radiator? I take it you still got the fans for the outer rads, then the speed will likely give enough flow for the middle one. It´s obviously not a road car that will be sitting in slow traffic, so I´d suggest you get rid of that extra weight!
10-06-2020, 05:04 PM
#78
OzCoolingParts Pro 3 Row Core All Aluminum Radiator + 2 x 12" Fan w/Shroud Kit for 1963-1968 64 65 66 67 Chevy Bel-Air/Impala/Biscayne/Caprice, Many Chevy GM Cars https://www.amazon.com/dp/B081YTZFD2/ref=cm_sw_r_cp_api_i_WLdFFbJTZEMCJ]
Awesome! Thanks a bunch! I'm using a toyota corolla radiator with an electric water pump right now but the radiator isn't up to the demand I'm producing with my rally boxster. I have to say I think your boxster build is the most intriguing build ever. My hat is off to you. Keep it up, it's very entertaining.
Woody
10-06-2020, 07:00 PM
#79
25lbs for the dash evap and heater core
10-08-2020, 04:41 AM
#80
Good point..I’ve removed the fans from the outer rads for this reason. I probably don’t need any fans and could just place a fan in front of the rad in the paddock once I come in if I want the car to run and cool down.
2003 911 C2
