Old 09-10-2023, 09:21 AM   #15
Franco's Avatar
Originally Posted by Brad604 View Post
I see I am replying to this thread about a month late but the answer is NO, you DO NOT have to remove the strut to replace the front bump stops! Do not waste your time removing them. You simply undo the single strut nut under the plastic cover under the hood. Then push the shaft of the strut down with a screw driver or something. Once it is low enough you can slip the old bump stop out from between the spring coils and put in the new one. Very easy and very quick job. Cutting of the bump stop is not required. You may have to use a deep socket and a hex key together to stop the strut shaft from rotating preventing the nut from coming off, or if you have a good impactor you may not have an issue. Let me know if you have any questions. I have done this job on my 2000 S with no issue.
Thanks just finished replacing my bump stops as per your instructions, 1 hour total.�� I also noticed that the strut shaft has no resistance easy down and easy up, is this normal thanks?
Franco is offline   Reply With Quote
