If you're going to do all that work to replace a couple bump stops, the while you're in there list includes new shock mounts, all the front end parts may also need replaced. I just did a reasonably involved front end refresh with new control arms, sway bar links, tie rod ends and struts. I ended up finding a couple of really nice fully assembled low mile takeoffs and saved the hassle (and some money) over replacing shock mounts, dust boots and bump stops and still having the same shocks. You'll need an alignment so that's why the other items are there on the while you're in there list.
