Old 10-14-2018, 03:40 PM   #1
Short Shifter Install - Won't Go Into Gear(s)
I installed Ben's short shifter and a Function First linkage into a used 986 shifter chassis with new shift ends. The assembly went fine.
I marked the shifter cables before removing them from the 997 shifter that was in the car.
After installing the short shift assy, I can't get into any gears.
I spent 45 mins trying multiple adjustments of the shift cables to find a spot where they would work and still no joy. It won't go into any gears.
Any suggestions appreciated.
Old 10-15-2018, 02:43 AM   #2
WillH's Avatar
Did you remove the green coin guard from under the original shifter before installing the short shift kit? If not it might be the problem.
Old 10-15-2018, 03:16 AM   #3
Oggie's Avatar
You haven't accidentally swapped the left and right linkages?
'99 base Boxster (Arena Red Metallic/Savanna Beige)
'02 911 Carerra Cabriolet (Arctic Silver/Metropole Blue)
Oggie is offline   Reply With Quote
Old 10-15-2018, 09:13 AM   #4
jaykay's Avatar
This is odd usually it's reverse that won't play ball as there is contact with the inside of the shifter console......requires some fine tuning.
I seemed to remember starting with marked cable positions and then adjusting step by step until I could get all gears......hot and cold.
Did you remove and install in neutral?
986 00S
Old 10-15-2018, 10:16 AM   #5
steved0x's Avatar
Is your shifter up on a riser where you can get to it without having to take a lot of stuff on? What if you take the two ball ends off and manually move the cables to shift gears? Then put just one ball end on (the one that connects to the bottom of the shift lever for fore/aft), move the other cable to the middle (it should go there by itself if the ball end is off and you press the clutch) and then try that one to verify fore/aft (3/4) gear change and see what happens.
Does the shift arm hit anything?
If it all works, then add in the left/right cable. When I first bought my car it was misadjusted and the ball end rubbed heavily on the shifter body, the rubber got chewed off, which made it rub more, etc...
Old 10-18-2018, 02:41 PM   #6
Well, this is a bit embarrassing...
Of course, I did. I'm an idiot. And that is what idiots do.
Swapped cables back and bingo, I have gears!
Old 10-18-2018, 04:50 PM   #7
2003 Base 5-speed
grc0456's Avatar
All’s well that ends well. Who amongst us hasn’t had a similar experience?
Old 10-18-2018, 09:46 PM   #8
Racer Boy
Racer Boy's Avatar
I've never done that particular dumb thing, but I've done plenty of others! Glad you got it figured out.
Old 10-18-2018, 10:40 PM   #9
Nope, I’ve never done anything like that EVER... HAHA! Glad you got it sorted.
Old 10-19-2018, 01:18 AM   #10
Oggie's Avatar
Glad you got it sorted!
Old 10-19-2018, 06:01 AM   #11
husker boxster's Avatar
So how does it feel now that it works?
1989 928 S4 5 spd - black
