01-25-2011, 09:29 AM
#282
Vendor
Originally Posted by nefarious986
Hi nefarious986,
I've stated as Race Version due to the sound level for some people are too loud, Honestly for me its just right to make the Boxster more aggressive Exhaust note.
We only offer this exhaust, no other options. Just ignore my descriptions about Race Version, that is just a advance warning for people want quiet exhaust
No CEL been reported by customers with this Exhaust combined with our Headers.
Thank you !
Che
John (Che) Lin
www.topspeedauto.com
http://stores.ebay.com/TOP-SPEED-PRO-1-PERFORMANCE/_i.html?_nkw=porsche+&_cqr=true&_nkwusc=porche&_si d=24549228&_rdc=1
http://www.facebook.com/profile.php?id=100001535057084
01-25-2011, 06:48 PM
#283
Carnut
Bypass pipes???????
'14 Boxster
01-28-2011, 08:59 AM
#284
Vendor
Just a Quick update for every members
Anyone with Performance Headers Installed on Boxster's any brand or make including our Headers. Please double check to make sure the P/S Line are secure away from Headers or else is hazardous to cause engine fire.
Che
John (Che) Lin
02-07-2011, 03:37 PM
#285
Originally Posted by BYprodriver
Thanks Che, I just ordered a set of headers for Boxster S on wednesday. I bought the 97-99 style from you 2 years ago but i need the O2 sensor bungs on the header. Will you be making Secondary cat. bypass pipes?
Che,
Well I received the new style headers & I am disappointed in the new style flanges. The flange transition to primary tubes is the worst I have ever seen, (I used to sell headers at a warehouse distributer speed shop) also the collecter to secondary cat pipe 3-bolt flanges are thinner & have elongated universal style bolt slots not oem style holes. Oh well I need the dual O2 sensor bungs per header for my 2000 Boxster so I guess I will have to give up some exhaust flow due to poor tube fitment to get the O2s on the header. I shipped them off right away to get them ceramic coated inside & out for $170. This will retain more heat inside the headers to bring O2 sensors up to temperature quicker & limit radiant heat to engine compartment. Headers came back from ceramic coating & I finally have time to install them, sold my 97-99 style TopSpeed headers for $100. New headers are harder to bolt to engine due to tube routing but I get it done then realize the O2 BUNGS ARE ON THE BOTTOM of the collector facing down & there is no way the wires are long enough to reach the connecters. The bungs must be on the top of the tube facing up for the wires to reach not to mention to prevent a loss of ground clearance. As I start unbolting them to put my stock maniflods back on I notice the PASS. SIDE DENT for engine clearance is in the wrong spot & has no effect other than to block exhaust flow. Great I have $400. "invested" in useless ceramic coated pipes & I just sold the last set I bought from you.
02-08-2011, 09:32 AM
#286
Vendor
Che,
Sorry for late reply, was out of office all week. This Headers for Boxster 00-04 model are always been the same design since I've been on this forum  .
Please send the header back to us this way I have access on the Header you had received and compare to our inventory stock Headers. Regardless will have issue resolve, please return back to:
delubozparts
4109 Billy Mitchell Dr
Addison,TX 75001
I will reimburse the Return S/H just include a Shipping receipt with the Header package.
Thank you and My apologies on the issues you had experience,
Che
John (Che) Lin
02-08-2011, 02:23 PM
#287
Che - just to back this up, the 'dent' on my left side bank was also in the wrong place, I had to install that side multiple times to wack again with a hammer and test fit before getting it all to clear the motor. The end result is ok, just has more of a dent than required and was a major PITA.
Something has gone off in the manufactoring area if these dents were lining up before.
sam
02-09-2011, 09:02 AM
#288
Che I am putting the headers on for a race this weekend & I have spent $400. on the headers with a ceramic coating. The pictures on your website look like the O2 bungs are in the same place as my headers so I doubt you will give me back $400. so I am going to try & extend the wires for my O2 sensors.
02-09-2011, 09:49 AM
#289
Just a question. Why are you guys buying headers that need a dent in them to fit? Have there been dyno results on these headers? Im not trying to be a p.i.a. I was just curiouse.
02-09-2011, 02:33 PM
#290
JAAY - read the entire thread (when you have a spare couple of days!!) and you will see that they have been dyno tested with good results.
I think I have found a way to get better results from them though. First of all, they should be ceramic coated, this keeps the heat inside, keeps the o2 sensors happy and produces more power due to the exhaust temp staying inside the pipe. Secondly, the mid pipes need to be modified or changed completely to have a 2" opening as this is the size that these headers are at the flange. The stock 2.5l mid pipes are 1.75" here and it creates a huge amount of turbulence and therefore restriction at this point.
The dent, will cause minimal if any restriction or power loss, its nothing much and normally just pushes the pipe into an oval shape anyway so you dont lose any flowing area.
Sam
02-10-2011, 09:57 AM
#291
Good question JAAY, my excuse is back in 2005 the Topspeed F1 was the 1st header I had seen for a resonable cost, $250, so I bought them & discovered the pass. side needed to be dented for engine clearance. It was either this or pay $1,000+ for a set of headers. Now in Oct. 2010 I see the new 2000-2004 Boxster 3.2 header with 4 O2 sensor bungs for sale by the same seller for $205, so assuming these will be of simular quality to the 1st set I buy the new version. As for dyno results I am sure I am gaining power over the OEM 2000 exhaust & I am sure the $750+ I saved cost me 5-10hp.
02-10-2011, 10:08 AM
#292
Vendor
sam
Sam,
Thank you for chimed in, these headers we had in-stock are made in 2 different production dates. in year 2008 & 2009 do you still have the box ??? Outside the Box should have a Label showing the date. If you don't have the Box will you be able to email the pictures to deluboz@aol.com this way I can take a look and compare.
Che
John (Che) Lin
02-10-2011, 10:14 AM
#293
Vendor
Just doubled checked our sales records from Dec 2010 to current date sold 28 sets, No reply back from Customers address issues.
Just need your help to double check the Header you had received, on the Package Box should have a white paper showing production/shipping date.
Headers we had in-stock are made in 2 different production dates. in year 3/10 2008 & 4/22 2009 Please let me know which production date Header you had received.
Regardless, will do my best to have problem resolve.
Thank you !
Che
John (Che) Lin
02-10-2011, 11:05 AM
#294
Che thank you for responding quickly here to address my complaint as you have for other customers throughout this forum. I don't want to ship these headers back & find out that this is how they all are & you offer a refund for what I paid for them but not the ceramic coating I paid for as most businesses would. The pics on your website seem to have the same O2 bung position as what I have here. I will take pictures & send to you since I can't upload pics on this forum.
02-10-2011, 11:46 AM
#295
Vendor
You are welcome, my direct email deluboz@aol.com Thank you for being patience working with me.
Che
John (Che) Lin
02-10-2011, 12:25 PM
#296
che -
do you offer - or plan to offer - cat bypass pipes?
02-10-2011, 02:43 PM
#297
Vendor
Originally Posted by insite
che -
We are working on cat bypass Pipes (Test Pipes) hopefully will be ready by early summer.
Boxster 2.5L 97-99
Boxster 2.7L & 3.2L 00-04
Will Post updates as soon is ready.
Thank you !
Che
John (Che) Lin
02-13-2011, 10:01 PM
#298
Originally Posted by delubozparts
...Regardless, will do my best to have problem resolve ....
That's the kind of response that I really appreciate from a supplier.
02-18-2011, 06:20 AM
#299
Will the proposed test pipes match up with OEM headers and muffler?
If yes, I am interested.
02-21-2011, 08:07 AM
#300
Vendor
These Test Pipes will match up with OEM Headers and Exhaust.
John (Che) Lin
| Thread Tools |
| Display Modes |
Linear Mode
