Old 05-08-2008, 08:28 AM   #241
Wingnut2u's Avatar
Kevra,
Yeah I don't understand, 4 hours, that is just unacceptable!
I just installed mine myself and the quality is great, definitely lighter than the stock exhaust. If you are expecting a major change in the sound, you will be disappointed. While it is louder, it is still very subdued which isn't a bad thing, just depends what you are wanting. Personally I would still like a little more rumble, maybe after I add some headers.
The butt dyno did detect an increase in hp but that also could be psychosomatic. All in all you will be pleased with your purchase even if the customer service is lacking jk
Wingnut2u is offline   Reply With Quote
Old 05-10-2008, 07:32 PM   #242
i have a question. with the mid pipe and headers
which one set of cat are eliminated. does the CEL turn on?
fu03steve is offline   Reply With Quote
Old 05-11-2008, 11:24 AM   #243
On all 2000+ boxsters the pre-cats or warm up cats right by the motor are eliminated with all aftermarket headers except Fabspeeds which are a header with high flow cats.
Che, you need to bring a Fabspeed header knockoff to market and sell it for half the price. You'd probably sell a ton if you can make something like these. As you probably know, all the bungs in the world won't prevent a CEL from happening unless you have some cats.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
Old 05-11-2008, 10:23 PM   #244
Send a message via AIM to blinkwatt
Che,
4 o2 sensor bungs??????
http://cgi.ebay.com/ebaymotors/Porsche-Boxster-2-7L-3-2L-00-05-Exhaust-Header-Headers_W0QQcmdZViewItemQQcategoryZ33631QQihZ020QQ itemZ300216614819QQtcZphoto
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 05-12-2008, 08:32 AM   #245
He doesn't mention if the 4 bung headers will cause a CEL or not. My guess is they will. I guess we'll see once somebody tries them.
Old 05-12-2008, 08:02 PM   #246
so those 4 bung are for the o2 sensors then huh?
if i was to remove the 2ndary cat close to the muffler...
will CEL turn on/?
Old 05-13-2008, 08:19 AM   #247
will CEL turn on/?
Yeah, it probably will. In layman terms the sensors that were aft of the cats will sense too much pollution and think your cats are not functioning properly so there's a good chance it will trip a CEL light.
Old 05-13-2008, 09:26 AM   #248
Wingnut2u's Avatar
Where's Che?
Che has totally disappeared from this site. I guess business is good.
That's too bad because like many others on this site I am interested in his headers but not without having the questions posted on this thread answered first regarding the CEL's
Old 05-13-2008, 09:31 AM   #249
Send a message via MSN to CJ_Boxster
hes around, Hes still a site sponser... His Ad is the one that says DelubozParts
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 05-13-2008, 09:31 AM   #250
No, he's been on here. he just hasn't posted a repsonse here. I clicked on his profile and it said he was actually here today @ Last Activity: Today 09:19. My guess is that he doesn't have reasonable solution to the CEL issue so he hasn't posted a repsonse.
Old 05-13-2008, 10:17 AM   #251
so a better solution is probably to keep the cat by the muffler...
and remove the first cat along with the headers?
would that be better?
Old 05-13-2008, 10:26 AM   #252
Here's the deal. If you want to avoid a CEL then you need to keep your stock manifolds or pay $2,300 for the Fabspeed headers I listed a pic of. The other main cats down stream by the muffler can be removed because there are no 02 sensors by them. Essentially the computer doesn't know if those cats are there or not. Here's a pic of the stock Porsche manifold that che's headers replace and all the others on ebay like his. If you replace this manifold with one without a cat then a CEL is likely. This is why companies like B&B don't make headers for 2000-04 boxsters. They know it will cause issues. The 2.5L guys however are in the clear and don't have to worry about all this stuff.
Old 05-13-2008, 12:17 PM   #253
Here's the deal. If you want to avoid a CEL then you need to keep your stock manifolds or pay $2,300 for the Fabspeed headers I listed a pic of. The other main cats down stream by the muffler can be removed because there are no 02 sensors by them. Essentially the computer doesn't know if those cats are there or not. Here's a pic of the stock Porsche manifold that che's headers replace and all the others on ebay like his. If you remove this manifold with one without a cat then a CEL is likely. This is why companies like B&B don't make headers for 2000-04 boxsters. They know it will cause issues. The 2.5L guys however are in the clear and don't have to worry about all this stuff.
oh i see!! thanks for the explaination. so the secondary cat ( by the muffler ) is save to remove and replace with test pipe... but there have to have a cat by the exhaust manifolds... i see...
Old 05-13-2008, 12:33 PM   #254
Steve... Im going to hit you!
You cant remove any of your cats without getting a CEL... You can remove the secondary cats IF and ONLY IF you have ROW settings flashed into your ECU or have revo flash your ECU to ignore the input from the last sets of o2 sensors.
If you look at the image, the cat on the right side has an O2 sensor screw in behind it so its expecting cleaner exhaust.
This is where the o2's are bolted to my exhaust on my 2.5.
Carlos J Cazares
Old 05-13-2008, 12:58 PM   #255
That diagram has me scratchng my head! It shows 8 02 sensors!! That diagram is screwed up! You should be able to replace those cats no prob.
[IMG][/IMG]
Old 05-13-2008, 01:00 PM   #256
That diagrahm has me scratchng my head! It shows 8 02 sensors!! I don't think that thing is right. You should be able to replace those cats no prob.
[IMG][/IMG]
That image is from the porsche parts cataloge, its just showing all the possible locations an o2 sensor CAN go.
Carlos J Cazares
Old 05-13-2008, 01:02 PM   #257
Yeah, I see it's trying to show both the old 2.5L system and the later system together. Confusing!!
Old 05-13-2008, 01:07 PM   #258
Nah, heres the image of the 2.5 liter engine exhaust system from the cataloge.
Carlos J Cazares
Old 05-13-2008, 01:13 PM   #259
I think this means i still get to slap Steve upside his medulla oblongata!
Carlos J Cazares
Old 05-13-2008, 01:19 PM   #260
lol.....yeah, I see what you mean now. Thanks for the info man.
