Old 01-23-2018, 04:35 PM   #21
Hinemn
I will see the extend of the damage once I pull the engine our and apart, you're not the only person who didn't replace the rings. How did you instal the wrist pins for cylinder 4,5, and 6?
Hinemn is offline   Reply With Quote
Old 01-24-2018, 12:34 PM   #22
Beginner
Jamesp's Avatar
Watch all of the glenn986 videos. They are quite good and will answer your questions.
2003 S manual
Old 06-27-2018, 06:25 PM   #23
Hinemn
A quick update on the dead Boxster, I will keep this short.
After a some contemplation about what to do with the engine with IMS bearing failure I decided that either a complete rebuild or used engine was the way to go.
The car is rust free and still holds its original paint which meant to me it was worth spending some time and money on it but not too much money.
So shortly after the end of this thread I found the same year and model Boxster on eBay. The car was a Flood car located in NY, when I say flood I mean nothing worked, all the electrical was pooched and I had no idea if the engine was any good or how many miles were on it, so I decided to take a big leap of faith and buy it.
The engine is in the car and I took video of the whole project and if I can find the time to edit them I would like to put on them on youtube so maybe I shouldn't give it away weather the car runs or not.
Old 11-20-2018, 12:22 PM   #24
BOOTLEG's Avatar
JamesSP,
Thx for the warning to lock the engine before disassembly or risk damage. Can you specify the damage? I bought a roller and just dropped the engine. Looks like the PO overheated it - 2 melted spark plug tubes but oil in filter & sump is clean. Want to disassemble but cannot rotate at all so TDC cannot happen. Any thoughts how I can avoid the damage in your warning?
BOOTLEG is offline   Reply With Quote
Old 11-20-2018, 08:45 PM   #25
jaykay's Avatar
Do you mean 986fix.com.......authored by Glenn? Yes, nothing beats a good mechanical engineer
986 00S
Old 11-21-2018, 01:50 PM   #26
jsceash's Avatar
Turning the engine to Zero will take most of the spring tension off the cams. The valve cover acts as the bearing caps for 2/3 of the camshafts. Once removed the cams can be damaged if too much spring tension is left on them.
Old 11-22-2018, 03:14 AM   #27
BOOTLEG's Avatar
Thx for the explanation. Now, in my case, because the engine cannot rotate, is there another way???
Old 11-22-2018, 05:58 AM   #28
jsceash's Avatar
Try to take the chain tensioner springs out of the block. Remove the chain sprockets screws on the cams to Let the cams settle on their own and remove the valve covers.
Tags
engine , ims bearings , manual , metal , rebuild
