10-03-2017, 01:27 PM
Spark plugs, or plugs and coils?
Im gonna attempt to change my brakes, and i figure ill go ahead and change the plugs while im at it. 56k miles, so its probably due for a plug change. So should i change the coils or anything else while im at it and the wheels are off?
Joe
10-03-2017, 04:08 PM
'01 S still? What was done at 30k?
10-03-2017, 04:54 PM
Joe
I have the original coils in my 2000 S with 121,K miles, no reason to replace them until you get misfires indicated by a trouble code for that cylinder, & it's not caused by failing to fully engage the proper wire to it's coil.
10-03-2017, 05:48 PM
coils (esp on a flat six) react very poorly to salt and will corrode. inspect them and look for any instance of the cover peeling back and exposing the innards. you can wait for a code, but if they look like they are weathering poorly then perhaps good preventative maintenance to replace them. often the inner workings can be exposed but not throw a code until driven in wet conditions and get splashed w water.
10-03-2017, 08:43 PM
At 60K, you should be doing a major service; - Replace oil & oil filter
- Replace engine air filter
- Replace cabin air filter
- Replace serpentine belt
- Replace spark plugs
- Replace fuel filter
- Check ECU for any codes
If the brake fluid hasn't been changed for two years, its time for new brake fluid also.
If the coolant hasn't been changed in 10 years, I would change that also. Its supposed to be "lifetime" but no one really believes that.
Everything else should be inspected and all other fluid levels checked. I wouldn't replace the coil packs unless they look damaged or the engine is reporting a misfire.
10-04-2017, 12:45 PM
I dont know, it had 46k miles on it when i bought it. And yes, still the 2001 S.
Joe
10-04-2017, 12:49 PM
I change the oil and filter every 3-4k miles, just replaced the air filter about 2 months ago, im gonna change the serpentine belt this winter when i put in my new water pump, i have no idea when the last time the fuel filter or brake fluid has been changed. Ill change those while im at it. Thanks for the checklist!
Joe
10-04-2017, 06:35 PM
If you have any sign or history of any oil leak in the vicinity of the spark plug area, I would consider replacing the spark plug tube o-rings "while you are at" replacing the spark plugs. There are two o-rings per tube, and even genuine Porsche parts here are not very expensive. The spark plug tubes will be accessible when you have the coils removed to replace the spark plugs.
Spark plug tubes
As for the coils themselves, as I demonstrate in above-linked post, I would recommend cleaning their exteriors, and giving them a very careful inspection them when you are changing the plugs. Be on the lookout for any cracks. All six of the coils on my 120k mile, 2001 2.7 looked perfect and wouldn't be able to be distinguished from brand new coils after being cleaned up, (with the exception of a couple of the the silicone rubber boots having small tears - available separately as Porsche part number 996-602-105-00).
2001 Boxster
