At 60K, you should be doing a major service;
- Replace oil & oil filter
- Replace engine air filter
- Replace cabin air filter
- Replace serpentine belt
- Replace spark plugs
- Replace fuel filter
- Check ECU for any codes
If the brake fluid hasn't been changed for two years, its time for new brake fluid also.
If the coolant hasn't been changed in 10 years, I would change that also. Its supposed to be "lifetime" but no one really believes that.
Everything else should be inspected and all other fluid levels checked. I wouldn't replace the coil packs unless they look damaged or the engine is reporting a misfire.
