Originally Posted by thstone
At 60K, you should be doing a major service; - Replace oil & oil filter
- Replace engine air filter
- Replace cabin air filter
- Replace serpentine belt
- Replace spark plugs
- Replace fuel filter
- Check ECU for any codes
If the brake fluid hasn't been changed for two years, its time for new brake fluid also.
If the coolant hasn't been changed in 10 years, I would change that also. Its supposed to be "lifetime" but no one really believes that.
Everything else should be inspected and all other fluid levels checked. I wouldn't replace the coil packs unless they look damaged or the engine is reporting a misfire.
I change the oil and filter every 3-4k miles, just replaced the air filter about 2 months ago, im gonna change the serpentine belt this winter when i put in my new water pump, i have no idea when the last time the fuel filter or brake fluid has been changed. Ill change those while im at it. Thanks for the checklist!
Joe
