Old 12-07-2017, 06:59 AM   #41
78F350, Thank you for sharing! that was an interesting post, it seems that the more I read the more I found out that there is always something new to be learned.
Old 12-07-2017, 08:13 AM   #42
78F350, we have a 40 valve motor. I have the benefit of a full machine shop plus I have been fabricating for over 40 years and mostly build titanium bicycle frames for a living. Making spacers and the engine cradle are easy work. The plan is to make a cradle that will accept 2.7L V6 or 4.2L V8 with just a different front motor mount for the block. We have both motors and 986 5 speed and 6 speed trans in the shop. Seems like most folks are going with a 987 6 speed trans so the starter plugs in the correct location...
What did you do with the starter location for the 986 5 speed?
titaniumdave is offline   Reply With Quote
Old 12-07-2017, 08:39 AM   #43
https://www.ebay.com/itm/Cedar-Ridge-Fabrication-adjustable-length-exhaust-hangers-NSX-Honda-Acura-Subaru/332161193201?hash=item4d565994f1:g3IAAOSwuxFY0Un H&vxp=mtrhttp://
Here is a part I make for the early Acura NSX that may be helpful with these motor swaps, lots of folks buy these for many applications so figured I'd post it up here.
Old 12-07-2017, 08:54 AM   #44
78F350's Avatar
Originally Posted by titaniumdave View Post
... What did you do with the starter location for the 986 5 speed?
The 5 speed bolts right up with the Audi engine. No need to modify for the starter. The clutch slave from the 5 speed looks a little different, but both mount and seem to work identically. The shift cables and linkage need to be swapped with the 5 speed. The axle stub does not swap from the 6 speed to the 5 speed, so I'm using the whole 5 speed axle. It's just a bit short on the hub.
... Making spacers and the engine cradle are easy work. The plan is to make a cradle that will accept 2.7L V6 or 4.2L V8 with just a different front motor mount for the block. We have both motors and 986 5 speed and 6 speed trans in the shop. ...
I'm quite dissatisfied with my current cradle and I'm not a good welder. If you come up with one that you are willing to sell and ship, I'm probably going to want it.
I gave a local fabricator measurements, the scrapped back 1/2 of a car, and this picture from Precision Chassis Works (for concept).
After 2 months of "It will done next week" and about $1,000 I had a heavy piece of scrap metal that was off by INCHES. Finally got it to fit, but not well. I'd love to see what you come up with.
Old 12-07-2017, 09:19 AM   #45
That layout is what I'm thinking for the cradle except with the Audi motor mounts so they can be a junk yard find, maybe add a torque link if it proves necessary, which I'm guessing it won't be needed for an NA build. For FI, seems like the drive line will be the weak link and my goal is a nice 300'/Lb torque from a motor we can track for a long time as long as no one money shifts it.
Old 12-09-2017, 12:58 AM   #46
is a cradle really needed? I am going with factory mounts as its only 100hp increase, that way you only need to fabricate an adapter to the front mount, I am going to modify the side mounts to allow a bit more exhaust clearance too, on the engine side I am removing the AC and PS pumps so mount bolts on there and then on the other side I am going to use the original Audi brace arm and also bolt through to the block in at least one place. I am using a GM astra electric power steering pump up front.
rusty69911 is offline   Reply With Quote
Old 12-09-2017, 06:01 AM   #47
78F350's Avatar
Originally Posted by rusty69911 View Post
is a cradle really needed? I am going with factory mounts as its only 100hp increase, that way you only need to fabricate an adapter to the front mount, ...
Needed? Probably not. I am following the build on FB too and I think that is a good, innovative approach. I like it. Before seeing that I was already convinced that the cradle that KCPAZ came up with was the way I wanted to go. I respect his skills and see the design as 'track proven'.
Old 12-09-2017, 08:01 AM   #48
Nice solution if you don’t mind loosing the AC. What I want to make is a part that you can maintain all the creature comforts plus use the stock Audi mounts for the PS and AC since it looks like they will hose up to the Porsche systems with only the addition of a reservoir for the PS pump. I agree there is no need for more engine mount that the stock Boxster ones, really come down to packaging for me and it seems just as easy to make one cradle than 2 separate mounts once the design is finished. The other goal is a way to use either V6 or V8 on the same cradle with just a motor mount swap, or hole location change.
Old 12-16-2017, 11:01 AM   #49
B6T
I think an advantage that the cradle has versus a singular front mount off the front of the engine is that the cradle can act as a stiffening member to better tie the bottom of the car together which may be helpful for the racers.
The guy in the FB build thread fabricated a small mount bracket that mimics the original flat-6 front engine mount, ie forward and lower from the crank pulley, which is also what I think rusty69911 is talking about too. That was the approach I was going to take because it seems to be the most simple and will offer lots of space on the side of the engine for future expansion.
I will have an engine to start taking measurements from in a month or so.
This looks like a very promising thread... lots of talent and skills. Can't wait to see how it progresses!
B6T is offline   Reply With Quote
Old 12-16-2017, 04:19 PM   #50
What happens when one of these swaps hits the smog testing site? What will the ECU report to the OBD2 port connected testers?
Old 12-17-2017, 09:05 AM   #51
B6T
It will report the VIN from the originating car. Unless you re-code it via a hex editor.
Now that I think of it, I'm not sure if it reports the engine type.
Old 12-17-2017, 09:40 PM   #52
78F350's Avatar
I've been living away from smog for most of my life and really don't know the details of what is required. If the engine swap itself is legal, it should be able to pass a smog test if done correctly.
I have learned the basics of flashing the ECUs used for these swaps and anyone else with very basic technical skills can learn it as well. It is not difficult to enter the correct VIN or load a modified file to the ECU. Knowing exactly what changes to make for tuning,.. or deleting the SAI is still beyond me, but the information is available for learning when my curiosity ventures there.
With some adjustments, the ECU should function properly and OBD port report normally. Need to be sure? Have a reputable pro do it.
For my car it doesn't matter. In Oklahoma there is not even a state requirement for a basic safety check
Old 12-18-2017, 08:59 AM   #53
Our current palm is to run 2 ECU, one for the car that shares outputs for the engine ECU that only controls the motor. The idea is to send just enough info to the car ECU that it thinks everything is good enough to run with out interference. For Oregon this will work for all cars prior to 2005 since there is not a need for ECU/VIN inspection, for later cars I am not sure how this will work if DEQ can 'see' both ECU plugged in.
Old 12-19-2017, 02:48 PM   #54
I just ordered a 987 6 speed transmission(with cables and axles) so I can get this project going, already have the 4.2L 40 valve motor. I'm going back and forth on the cradle design, using the front Boxster mount makes packaging easy and will simplify the front radiator line routing. Thinking this route will be a horse shoe shape that will pick up the motor in 2 locations on each side, at the transmission bolt up and the factory Audi motor mount location. This way all the bending moment is compensated for and the load is stabilized into a plane that can bolt up to the stock front Boxster mount. Front could be a flat plate to make it compact and help with packaging for accessories/belt run. Hopefully I can have pics of concept next week...depending on how the holiday messes with things.
Old 01-11-2018, 11:12 AM   #55
A little progress, the engine cradle in the next couple of weeks!
Old 02-01-2018, 05:14 PM   #56
Some of the parts for the motor cradle...hopefully get the rest tomorrow and can have it welded up this weekend!
Old 02-02-2018, 01:24 PM   #57
B6T
Can you make me one too please?
Old 02-02-2018, 01:36 PM   #58
Once I get one done and I'm sure it works the plan is to offer these for sale. Also make one for 2.7L V6 too for those who want to do the turbo thing! I should have this together this weekend and if I got it right.
Old 02-05-2018, 04:40 PM   #59
Cradle welded...next step to see if the motor fits in the car.
Old 02-05-2018, 04:43 PM   #60
Complete cradle is 8.5LB, I might have made it too light but it's surprisingly stout feeling, real question is fatigue over the long haul. An extra couple of pounds will most likely make sense.
