Old 04-29-2017, 02:08 PM   #21
I see where you mentioned the bent rims in the original post so I did miss it. IKO look no further than the wheels. Human eye cannot see the deviation.
nicecar is offline   Reply With Quote
Old 04-29-2017, 06:06 PM   #22
BYprodriver's Avatar
Originally Posted by AZ986S View Post
I just had all 4 wheels inspected and the 2 rear straightened (.035 and .060).
Then all 4 wheels/tires were Hunter roadforce balanced.
How would a reputable shop (Wheel Specialists, Tempe, AZ) verify that the straightening was effective? I would think without the tire mounted, but I didn't ask or witness it.
Unless extreme, I would tend to agree that alignment would not cause vibrations.
New wheels typically need 1/4oz weight to balance them, I would guess despite Wheel Specialists best efforts your rear wheels require a full 1oz just for the bare wheel.
Before debuting a unknown wheel on your car, always have it spun on a balancer & observe the up & down "hop", as well as the side to side movement to see what you are dealing with. Especially with new wheels since often they are non-returnable if a tire has been mounted.
Old 06-01-2017, 12:53 PM   #23
AZ986S's Avatar
Well today I went back to the tire and wheel shop to have the wheels checked again for out of balance. I've been battling the same vibration issue at 70 mph and higher.
The shop says all 4 wheels roadforced balanced less than 10 lbs and all is good as far as the wheels are concerned. So that leads me to believe that the suspension or steering is the culprit. Since I've observed no slop in the steering at all, and it is very crisp, I believe the LCA bushings or balljoints must be worn.
I have not replaced any suspension components other than the rear shocks after I bought the car last year. Front shocks rebound fine, no leaks. LCAs look old. Any way to tell for sure? If I do LCAs, should I also do the track arms?
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
Old 06-01-2017, 10:32 PM   #24
You'll probably find that the tuning fork bushes are worn and tbh there's no real way to just visually check them. When i replaced mine the old ones "looked fine" but you could virtually bend them in half with very little effort at all.
That986 is offline   Reply With Quote
