Old 08-21-2016, 09:57 PM   #5
When connected to trans they are stuck in neutral. The shift rod sticking out of trans. There is only one. Is jammed. Cannot shift it by hand at the trans. Where as normally you can use one hand to shift through the gears at the trans.
Timmyk is offline   Reply With Quote
