Originally Posted by Timmyk
When connected to trans they are stuck in neutral. The shift rod sticking out of trans. There is only one. Is jammed. Cannot shift it by hand at the trans. Where as normally you can use one hand to shift through the gears at the trans.
Put the rear up on jack stands. Rotate one wheel back and forth while you wiggle the transmission shifter lever on the side of the transmission. That may free up the mechanism. Are you sure the lever is actually moving the shaft that goes through the trans case?
