Old 08-21-2016, 05:16 AM   #3
Deadeye
First thing to check is the cable connections at the trans. If the cable outer sheath becomes separated from the clip that hold it to the case you get the symptoms you describe. If that is the problem you can snap the cable back into the clip and secure it with safety wire. Could also be the very end of the inner cable popped off the lever on the trans, but this is less likely.
Deadeye is offline   Reply With Quote
