04-21-2016, 05:55 PM
#1
1998 Boxster Owner
Timing check results
Before I got the chopsticks out and started measuring cylinder stroke to check for a bent rod, I popped the camshaft plug on bank 2 and looked at the timing. A couple of pics are shown below of the crank at TDC and the position of the camshaft. The phone camera was as level and as close as I could get. Imagine taking these with a 35mm camera? So, what do you all think? Pretty close.
https://flic.kr/p/GkziwW
https://flic.kr/p/FysP4r
04-21-2016, 06:07 PM
#2
This is a great picture of the intake cam. Could you post a picture of the exhaust cam so to see if the notches are straight up and down?
See post:
DIY: Setting Cam Timing on M96
04-21-2016, 08:55 PM
#3
1998 Boxster Owner
One last update. Did the chopsticks test. Difference between TDC and BDC on all six cylinders was 2.25 inches. No variance.
So at this point, I'm going to rule out a bent connecting rod and bad timing on bank 2.
On to cat testing tomorrow.
Thank you all for all your help and suggestions. I'm learning more than I ever thought I would.
Best regards, Tom
04-24-2016, 08:06 AM
#4
Best regards, Tom
Good result! Might check your measurement though. 2.5 liter has stroke of 72mm or ~2.8".
04-23-2016, 02:16 PM
#5
1998 Boxster Owner
Catalytic Converter Testing
Well I got the appropriate O2 sensors out and tested in front of and back of each cat. The gauge read almost zero on all four openings, so I will assume that back pressure is not the problem. On to checking for intake restrictions. Something may be blocking that side. Hoping it's not something long dead.
04-24-2016, 01:56 AM
#6
Hi Tom,
well zero means, that something is blocked. Right?
Please also check if the left side header and all connections points of the exhaust system on that side for new gaskets and screws - so the question is if some parts were removed lately. I've seen idiots that put in gaskets without holes. And because we don't know what the workshop did…
Regards, Markus
04-25-2016, 08:27 AM
#7
1998 Boxster Owner
Good result! Might check your measurement though. 2.5 liter has stroke of 72mm or ~2.8 in.
Hey, you said approximate!
Hi Tom,
No, it actually means the cats are free flowing. The gauge reads pressure in psi. I saw puffs on the gauge at all four O2 sensor holes but the pressure was negligible . If the cat was plugged, the readings in front of the cat would be higher.
So I'm running out of ideas. I'll go ahead and remove the throttle body and intake manifold, clean it, and look for any air restrictions to bank two and any vacuum leaks that may be present after getting the parts out of the way.
Any chance this could be a bad DME?
04-25-2016, 10:29 AM
#8
Motorist & Coffee Drinker
Maybe I missed it, but did you check the cam timing already from the link that "muscatty" posted?
The check is easy enough to do with the engine in.
04-25-2016, 10:34 AM
#9
1998 Boxster Owner
The timing on bank 1 was right on. I posted a pic of bank 2:
04-25-2016, 07:36 PM
#10
Hello tada,
i have a wiring diagram for the 99 986 dme. It's too big to post it here.
Looks like every ground point for each fuel injector runs seperately, but has an internal node.
The ignition has 2 ground points on the DME. But they are connected. The wiring loom runs to one central ground node, but there is a wiring running to each. Maybe a broken wiring loom cable? Did you recheck the ground connection on each ignition coil?
Don't know DME outs for one bank could be shot all at once. In general each out has his own power transistor.
If you pm me your e-mail address, i can send you the wiring diagram.
Regards, Markus
04-27-2016, 10:26 AM
#11
1998 Boxster Owner
On the vacuum trail ...
Going through the vacuum system for a bit. I have a question about the secondary air injection pump. I do not hear any sound coming from it during cold startup (not like I ever have warm startup). I left my windows computer at work, so my Durametric is helpless right now. Can a failed SAI pump cause this bad a problem? Thanks, Tom
04-27-2016, 12:49 PM
#12
Hi Tom,
in my opinion the engine should run proper just with a failed SAI. Maybe it will run too fat, but that wouidn't lead to a not working cylinder bank. Also the SAI blows air into the complete intake system – not only in one cylinder bank side.
Could a failed o2 sensor lead to a problem with one cylinder bank. I would say yes, but i don't think it could block the bank from running. And that is what it sounds like.
There must be a more fundamental problem.
Regards, Markus
05-08-2016, 12:15 PM
#13
1998 Boxster Owner
I finally found time to remove the throttle body and intake manifold. I expected to find it filthy, but instead it is pristine clean. Strange. I am still hunting a vacuum leak. When taking off the intake manifold, the vacuum tube to the fuel pressure regulator snapped at the point where it enters the "bellow" of the intake manifold. It may have been weak or leaking to begin with. I'm still going to clean the IAC valve and do some more smoke testing on the vacuum parts
05-08-2016, 03:32 PM
#14
Interesting.
If one vacuum lie is so brittle it cracked ,what about all the others if they are the same age & have endured the same heat cycling ?
Pelican sell a vacuum hose kit but I had wanted to find a set that are a better grade of plastic. In theory silicone may work for the small diameter hoses if you get a thick wall? It has a tendency to collapse under high vacuum when hot. So the cheapo EBAy ,thin wall silicone hoses would be a bad choice.
For smoke testing the vacuum system I recent;y upgraded to a better quality paint+can+baby+oil system.It works well because it pushes ut a lot of smoke for a long period consistently.
Thanks for letting us all follow your progress.
05-08-2016, 03:52 PM
#15
1998 Boxster Owner
Originally Posted by Gelbster
Interesting.
I'll replace them all if I could find that kit. I've searched for hours for the part number of the rigid vacuum line I need that goes from the intake manifold to the fuel pressure regulator. Porsche Atlanta shows it on a diagram as part 16, and then does not list it. Pelican has rigid vacuum line sold by the meter that is listed as 4.0 x 1.0 mm. If anyone knows the part number, I would appreciate it. Otherwise off to my local Porsche dealer.
05-08-2016, 04:00 PM
#16
For the hard line, try Sunset??? They have an excellent rep for helpfulness.
05-09-2016, 04:08 AM
#17
Hello tada,
is the part you're looking for on the chart, or am i on the wrong chart. If it's on the chart, which number has it. Could you alternatively link to the chart from Porsche Atlanta. Than i can look for the parts number.
Regards, Markus
05-09-2016, 04:40 AM
#18
1998 Boxster Owner
Thanks Markus and Gelbster. I was finally able to find the part number for the vacuum line - 00004320501. I appreciate the help, Tom.
05-09-2016, 07:04 AM
#19
Just throwing this out in an attempt to be helpful: any chance that the variocam solenoid on that bank has failed? And if it did, would it throw a code or light the CEL?
05-09-2016, 08:10 AM
#20
1998 Boxster Owner
I think it's a good idea. No CEL is being thrown. The only codes the Durametric is picking up is a low battery failure (when I disconnected it to reset the DME) and a P1541 when I jumpered the fuel pump relay. There should be a way to test the solenoid. If anyone knows, it would be appreciated. Thanks, Tom
Thread Tools |
Display Modes |
Hybrid Mode
