Old 02-27-2016, 02:29 PM   #1
New Porsche Fan
imari's Avatar
Air Injection Check Valve
I have a 2001 Porsche Boxster and the CEL is on. I took it to Autozone to get the codes:
P0410 - Secondary Air Injection System, Bank 1
P1411 - Secondary Air Injection System, Bank 2 - Below Limit
It recommends replacing the Air Injection (AIR) Check Valve.
I went to check Ebay for the part and I'm seeing a couple of different things there (part looks different, price varies from $25 to $125, etc). Is anyone familiar with this enough to make a recommendation. Is this an easy fix or should I go to an Indy? I appreciate any advice. Thanks in advance.
2001 Black Boxster
2004 Red Vespa 150cc
2006 Black Maserati QP
2008 Black VW Eos
2010 Charcoal Ford Flex
imari is offline   Reply With Quote
Old 02-27-2016, 05:39 PM   #2
jsceash's Avatar
P0410/1411 Bank 1 & 2 below limit
Possible fault cause
♦ Secondary air injection pump is not triggered
♦ Secondary air injection pump does not work
♦ Air supply lines restricted
♦ Electric change-over valve does not function
♦ Air change-over valve does not function
♦ Vacuum system leaking
Start by looking for a vacuum leak. Any of the small tube off. The large hose from change over valve to pump cracked or off. Bad change over valve (This is under the passenger side intake).
Old 02-27-2016, 08:17 PM   #3
Motorist & Coffee Drinker
78F350's Avatar
^ That.
Then if it is a valve, in the Air Injection, it's this:
Not a "check" valve.
Another possibility (rare?) is that the passages at the exhaust manifold are clogged. Jager did a great write-up a while back:
http://986forum.com/forums/general-discussions/49666-p0410-secondary-air-injection-system-cylinders-1-%96-3-a.html
Old 02-27-2016, 08:48 PM   #4
You'll need to do a thorough diagnostic of the entire system as the problem can be with almost any of the components. Finding the real fix can be a PITA.
Here is my story of P0410/P1411: http://986forum.com/forums/general-discussions/41855-p0410-p1411-solved.html
Old 02-28-2016, 05:25 AM   #5
I had the same issue on my 2003, ended up having to have the whole system replaced due to hoses getting brittle due to age etc, total cost was around $1000 for a main dealer to fix.
jpl2407 is offline   Reply With Quote
Old 05-20-2018, 01:30 AM   #6
Here is a really detailed video showing how to diagnose and fix this:
And links to cheap new parts
https://youtu.be/go34DJAuPyg
Leonardo111 is offline   Reply With Quote
Old 05-23-2018, 08:45 AM   #7
the video is ok, but my experience is to start with inserting a vacuum gauge in the system and see if you have 14-18hg of vacuum. The vacuum canister is glued together and can leak. Canister is only $25 or so.
Replace the rubber vacuum lines with high temp silicon hose. heat and age dries the rubber hoses.
I found the vacuum source connection would not stay in the manifold. I replaced connector with a barbed brass one.
2003Boxster
1973 Carreras RS tribute
2000 Saab Aero wagon stick
1990 Chevrolet pu pre runner
boxfix is offline   Reply With Quote
