Old 12-12-2015, 12:26 PM   #1
I already changed the aos 2 years ago. I dont think it needs changing again as I don't use the car much. Is there a sure way to tell if it needs changing?
boxster is offline   Reply With Quote
Old 12-12-2015, 02:30 PM   #2
Connect a digital manometer to the oil fill cap and measure the crankcase vacuum at idle; should be 5 inches of water or less.
Old 12-14-2015, 02:57 PM   #3
1999 base
Meir's Avatar
i think you should replace the fork as well. for around $35, get the updated version so you will not end up with somthing like that down the road.
