Old 11-12-2015, 11:56 AM   #9
jb92563's Avatar
Originally Posted by epapp View Post
How do you keep the CEL happy with the cats removed?
Since the California cars have 2 cats per side, only the upstream cat on the header has sensors. I removed the downstream cats when I did my 2nd cat delete and Top Speed muffler install.
Since the upstream sensors and cat are functioning fine no engine light.
I also just passed the smog yesterday.
Apparently the Test has changed and for 2000 and newer, as mentioned in this thread, they don't use the tailpipe sniffer anymore, so if all your pollution codes on the computer are good then you pass.
My smog literally took 5 minutes as one guy hooked up the OBDII cable and the other guy took a peek under the rear.
Seems like $60 is too much now for that little work.
I think the next step if that you hook up your own computer to the OBDII and send your report directly to the DMV without the middle man.
Ray
