Old 05-13-2015, 12:14 PM   #1
CAN Bus speed on the 2004 Boxster?
For my conversion I am thinking of using a Orion BMS and an EVIC display. Both of these work of off the CAN Bus. That means I can connect (to) the vehicle's CAN Bus also. However all the CAN Buses need to be operating at the same speed.
The CAN Bus speed for both the Orion BMS and EVIC display, as expected, can be modified/configured. I would assume it is not possible/easy to modify the vehicle's CAN Bus speed. Therefore I will have to adjust the CAN Bus speeds of both these devices to the speed of the vehicle's CAN Bus.
Does anyone know 'what is the CAN Bus Speed of the 2004 Boxster Base model, or where I can find this info?
Thanks in advance for your help on this!
PorscheFan5 is offline   Reply With Quote
