Old 06-17-2015, 11:25 AM   #7
PorscheFan5
Thanks for the suggestions Qmullus. You are corect in assuming that my engine was not running whe I started the project. In fact I bought the vehicle with a busted engine intentionally...unbeknownst to this need...
I am where I am. I would like to see if I can use the current DME 7.8 for:
  • Not having to deal with ABS, Airbag etc lights
  • Use the current RPM sensor and wiring to display RPM on the stock dial in the dash. And not put another sensor on DC motor shaft and have to put another meter somewhere to see RPM
  • Any other info that I could get from the CAN bus that I can feed to my display using the analog or digital input connectors.
Could you spare a few minutes for a live conversation on the phone? I could get soe insights from your experience you mention. Worst case I will remove the DMW completely...Please PM me if you could spare me a few minutes.
Thanks!
PorscheFan5 is offline   Reply With Quote
