Old 04-23-2014, 09:12 AM   #1
Clutch bleeding problems
Checked past posts on clutch bleeding, and found a few posts that touch on the problem, but not one that closed with details on a successful fix.
Using Motive Pressure bleeder, pumped to 20lbs, clutch pedal held nearly to the floor with baseball bat, open slave bleeder valve and not much fluid comes out, but pedal collapses completely to the floor. Pressure changes very little, if at all.
Pedal needs to be pulled up by hand. Then depressed again, held with bat, and open valve again, same results. A little fluid trickles out, pedal collapses, little change in pressure gauge.
With 20lbs pressure, I expected a steady and significant stream to pass through the bleeder valve when opened.
Any thoughts please.
Thanks,
Joe
Xcellr8 is offline   Reply With Quote
