Old 03-11-2015, 10:17 AM   #41
JAAY's Avatar
logging it of course is best. You want the open loop numbers, that is when all the sensors are doing their thing and you are at WOT wide open throttle. The closed loop stuff will fluctuate but always kinda read like what you have gotten already. Closed loop is just cruising or idling. You want your open loop numbers to be around 13:1 for best performance. (disclaimer) I was advised this by somebody but please have your car tuned by a professional for safety of the motor and performance. Pedro can probably help or FVD. Giac if you can get them to get you on their dyno. I use a wideband 02 sensor.
JAAY is offline   Reply With Quote
Old 03-11-2015, 10:25 AM   #42
Need For Speed
KRAM36's Avatar
Yeah, you are absolutely missinformed.
K&N has designed these oil-saturated air filters definitely for injector engines. LOL!
@KRAM:
Sometimes it's better not to think too much.
Life is complicated enough.
I'm just wanting to make it the best I can lol. I could not keep the Helmholtz resonator on the tube. There was no room for it, so it had to be removed.
2003 Boxster S
Old 03-11-2015, 10:33 AM   #43
Need For Speed
KRAM36's Avatar
Ok, so I'll get my daughter to ride with me, lay the hammer down and have her log the info. She got to ride in it for the first time this morning. I have the speed gong set at 70, so I know to slow down to keep the spoiler from deploying. She heard the ding at said " we hit 70 already?" lol.
2003 Boxster S
Old 03-11-2015, 10:35 AM   #44
inveniam viam aut faciam
FWIW, here is a good study of air filters. I like tests with real data and there is a lot there. Bottom line, there is no free lunch. Interesting read if nothing else...
Qmulus is offline   Reply With Quote
Old 03-11-2015, 10:36 AM   #45
@KRAM36
You're welcome.
Don't forget that your AT-tranny will need an defined amount of variable underpressure to work perfect, and that the intake tube is designed to deliver exactly that underpressure.
Also consider not also the Helmholtz but also the Venturi effect when you do things in a new sophisticated KRAM36 way.
Old 03-11-2015, 11:15 AM   #46
Need For Speed
KRAM36's Avatar
Check out this video. This car also has a flat 6 in it and got a 5.7+ whp with just the K&N filter added. Also the longer the K&N filter is in the car, the better it traps dirt.
2003 Boxster S
Old 03-11-2015, 11:54 AM   #47
The Radium King's Avatar
I *think* the tip connection is only for vacuum, so not a lot of, if any, air movement through it.
you will need a wideband o2 sensor to measure afrs at wot. your car only has narrowband (ie, measures afr values in/around 14.7). ecu uses feedback from the narrow band sensors to keep afr at 14.7 at idle and part throttle though the use of fuel trims (ltft). this is closed-loop operation.
at wot the ecu wants to add a bit more fuel to keep things cool (ie, an afr of 13 as suggested by jaay). narrowband sensors don't work in this range so the ecu has no feedback on the afr it is providing - it just adds fuel based on the amount of air measured. this is open-loop.
open loop is the most critical, as this is when the engine is working hard and the opportunity for damage the greatest. if the maf is mis-reading air (ie, more air getting in than the maf reads) you may get into a lean situation which can kill your engine (gets hot, detonation occurs, pistons get holes in them).
how can the maf misread air? a larger diameter maf tube will do it. non-laminar flow in the tube can do it (ie, as jay notes, the ecu is calibrated to read airflow based on a certain type of airflow, and this airflow can be modified by bends - or the lack thereof - upstream of the sensor) vacuum leaks can do it, vibration can do it (ie, I thought it was good to have the maf closer to the tb for better throttle response, but this also resulted in the transmission of more engine vibrations) etc.
the thing is, all the factors that affect air metering at open loop operation are present at closed loop operation, so, check your ltfts and see if they are high. If they are then your open loop afrs will be off (my understanding is that the ecu does not use the closed-loop ltfts when running open loop). a little bit of lean operation is ok; Porsche oem afr at wot is 12.5; moving to a 13 should be fine (will result in more power and better fuel consumption) as long as you use a higher octane fuel.
blah blah blah ...
Old 03-11-2015, 11:59 AM   #48
JAAY's Avatar
Radium<<<<<<<<<<< Thank you for the better explanation.
Old 03-11-2015, 01:11 PM   #49
Need For Speed
KRAM36's Avatar
blah blah blah ...
How can I check the ltft? What is too high? Don't I need more miles on the car after the mods (less then 100 miles right now) before the computer sets the ltft?
2003 Boxster S
Old 03-11-2015, 01:24 PM   #50
Need help understanding Durametric fuel trim readings - 986 Series (Boxster, Boxster S) - RennTech.org Forums
Old 03-11-2015, 02:03 PM   #51
actually - you are the man here, as you've actually gone in with a piggy back and modified your fueling. perhaps you could help me - does the ecu use the trims established in closed loop operation to modify fueling when running open loop? you could probably determine that by resetting your ecu - as it re-adapts and resets trims, do you see open-loop fueling changing?
Old 03-11-2015, 02:24 PM   #52
Need For Speed
KRAM36's Avatar
I read Loren's response, but how do I equate that info into ltft? Loren doesn't say what the values should be.
I don't understand.
2003 Boxster S
Old 03-11-2015, 02:38 PM   #53
Porsche 986-996-987-997 Fuel Trim Information | Callas Rennsport
Old 03-11-2015, 03:38 PM   #54
edc
550 Anniversary
edc's Avatar
You could always stick your car on a dyno and get a plot of the afr across the rev range. My afr / fueling seems pretty good as is so it's hard to see aside from a bit more advance where you can make any significant inroads.
Current: 550 Spyder Anniversary- Carnewal exhaust - 100 cell cats - stainless manifolds - 4" underdrive pulley - poly gearbox mounts - rear lower alu brace - adjustable rear toe links
Sold: 986S - Zenith Blue - 18" Sport Classics - Black Zunsport grilles - Stainless silencer and manifolds - K&N panel - shortshift - M030 suspension - 75mm throttle body - custom 83mm intake - SmartTop - custom remap - MDS underdrive pulley
Old 03-11-2015, 03:50 PM   #55
Need For Speed
KRAM36's Avatar
That makes more sense to me.
My readings at idle and engine fully warm.
Range 2 (FRA) Bank 1 = 1.08
Range 1 (RKAT) Bank 1 = 2.86
Range 2 Lower (FRAU) Bank 1 = 1.08
Range3 Upper (FRAO) Bank 1 = 1.00
Range 2 (FRA) Bank 2 = 1.11
Range 1 (RKAT) Bank 2 = 4.13
Range 2 Lower (FRAU) Bank 2 = 1.11
Range3 Upper (FRAO) Bank 2 = 1.00
Not sure which MAF reading he was referring to as there are 2 to read from.
MAF (HFM) danced between 11 to 13
Mass Air Flow danced between 10.9 to 11.7
I'm also getting P0430 on the Quick Test
Porsche Fualt Code 45 Cat Conv. Efficiency Bank 2
2003 Boxster S
Old 03-11-2015, 05:36 PM   #56
Need For Speed
KRAM36's Avatar
So I gather from those readings at "WOT" open loop (FRA FRAU FRAO) my AFR is pretty much spot on, but at idle closed loop (RKAT) the AFR is running extremely lean?
2003 Boxster S
Old 03-11-2015, 05:58 PM   #57
these are closed loop values - no trims generated when at open loop (no feedback from the o2 sensors, so no trims). your fra numbers look good - oem Porsche is +/- 0.1. from what I understand, either
(a) your maf is mis-reading the airflow 10% low - vacuum leaks adding air, turbulent airflow into the sensor, vibration, old maf sensor, dirty maf sensor (oiled filter ...) or
(b) your fuel system is delivering 10% less fuel than requested - dirty injectors.
again, the 10% is within Porsche spec, so looks all good (although you might need a few more miles to get the ltft to settle down).
dunno much about idle, other than, if it is idling ok, then I wouldn't worry about it.
Old 03-11-2015, 06:12 PM   #58
did a bit of searching for you and the rkat is high. did you reset the ecu? otherwise perhaps check for air leak. a small leak has more effect at idle than it does at part or full throttle.
Old 03-11-2015, 06:24 PM   #59
Need For Speed
KRAM36's Avatar
Does disconnecting the battery reset the ecu or do I have to do that with the Durametric? The car set for around 5 days with the battery disconnected.
2003 Boxster S
Old 03-12-2015, 04:09 AM   #60
JAAY's Avatar
14.6:1 is normal for cruise and idle. That number bounces around a bit but is fine. I use an aem uego wideband gauge and sensor to tune up my car along with a piggybacked air flow manipulator. I use an old apexi afc select. I believe any newer one would also work. I dont have logging software but just do it the old school way. Either on a dyno or a good old stretch of road and 4th gear.
