Old 03-11-2015, 07:24 PM   #14
KRAM36
Need For Speed
KRAM36's Avatar
did a bit of searching for you and the rkat is high. did you reset the ecu? otherwise perhaps check for air leak. a small leak has more effect at idle than it does at part or full throttle.
Does disconnecting the battery reset the ecu or do I have to do that with the Durametric? The car set for around 5 days with the battery disconnected.
2003 Boxster S
