Old 03-08-2015, 12:09 AM   #1
Again AOS failure
Hello,
When starting the car began to smoke, and I remove air intake and found therein oil I bought a new air oil separator and smoking stopped at startup. After about 1000 km appeared white smoke while driving. At a moment when the car began to smoke in white, started flashing CEL, now only lights. Now I disassembled the air intake and again found oil. It looks back on air oil separator. Is there any reason that could have a new air oil separator destroy?
Thank you!
Sm33C is offline   Reply With Quote
Old 03-08-2015, 12:56 AM   #2
How does the white smoke smell?
Did you check the car for error codes?
Old 03-08-2015, 04:05 AM   #3
Smells like burnt rubber. Error codes will try to find out.
Old 03-08-2015, 12:34 PM   #4
Beginner
Jamesp's Avatar
Is the smoke coming out from under the car, or out of the tailpipe? If its coming out from under the car and smells like burning rubber, check the belt. An accessory pulley may have frozen up.
2003 S manual
Old 03-09-2015, 02:17 AM   #5
Smoke comes from the exhaust. Disgnostiku I have in the course of this week.
Old 03-09-2015, 09:51 AM   #6
There seem to be 2 things that are the 'final straw' for a weak AOS diaphragm:
1.overfilling the sump
2.tracking + 1.above.
Are you sure you did not overfill ?
Old 03-11-2015, 08:27 AM   #7
Yes, I'm sure. I'm afraid that the reclamation AOS will not be successful.
Old 03-17-2015, 02:05 AM   #8
Diagnostic returns P0410 and P1411
Old 03-17-2015, 10:20 AM   #9
Greetings to you in Prague
There is a simple test for AOS failure- try removing the oil-filler cap and test the vacuum."Search" 'slack+tube+manometer'.
I hope you have somewhere warm to work on the AOS replacement- tedious job.
Old 03-17-2015, 01:08 PM   #10
Engine Surgeon
What brand was the AOS? Uro brand?
US Patent 8,992,089 &
US Patent 9,416,697
Old 03-18-2015, 02:18 AM   #11
AOS was purchased at the Porsche dealership in Prague, AOS I mounted DIY.
Old 03-18-2015, 02:31 AM   #12
Thank you, I'll do a test vacuum. Oil-filler cap can be removed very difficult (made before installing the new AOE and after installation too), it can be a symptom of the loss of vacuum?
Old 03-18-2015, 10:12 AM   #13
It sounds as if your vacuum is normal. The difficulty with overcoming the vacuum when you try to remove the oil-filler cap indicates that the diaphragm of the AOS has failed.
Suggest you " Search " AOS failure before you proceed -it is a frequent subject.
Old 03-18-2015, 01:21 PM   #14
Found this video describing the vacuum test and AOS failure:
https://www.youtube.com/watch?v=FKmjatZmUo0
Old 03-19-2015, 09:08 AM   #15
I hope he managed to clean his lungs !
For our overseas readers who speak/understand English-English, the word
" oil " is contorted to 'awahl' in this video. It is the same fluid despite the pronunciation change ;-).
Tags
(aos)(separator)
