Old 03-18-2015, 10:12 AM   #13
Gelbster
It sounds as if your vacuum is normal. The difficulty with overcoming the vacuum when you try to remove the oil-filler cap indicates that the diaphragm of the AOS has failed.
Suggest you " Search " AOS failure before you proceed -it is a frequent subject.
