Old 03-14-2015, 02:26 PM   #61
Need For Speed
KRAM36's Avatar
I realize you have now seen the light and understand that the spoiler goes up and down at a specific speed for a reason and does not lower mpg as that was your concern. So if getting better mpg is your concearn, why are you looking at increasing HP with a bunch of engine mods in another thread? That will surely decrease MPG. The easiest way to increase MPG is to slow down a bit, especially if you are going 70+
My answer is in the quote, but it's no longer an issue in mind.
2003 Boxster S
Old 03-31-2015, 04:29 PM   #62
jb92563's Avatar
If you did not see your spoiler come up at 75mph, then did it actually happen?
Your mileage will vary depending on what you think happened as indicated by the little spoiler light on the dash.
Now to the aerodynamics
Spoilers are in fact designed to spoil lift, hence the word used to describe then, and in our case since it is also behind the the aerodynamic center of lift it may also generate a bit of down force due to the force vectors generated, all designed to enhance stability and so the rear rubber stays firmly planted on the road so you don't loose the tail and end up pointed in some direction other than intended.
I would not mess with that if you drive over 75 often as the chances of loosing control/stability will increase and the Porsche designers will just shake their heads wondering why someone would defeat their measures to keep you in control.
Embrace the perceived ugliness and know that many are appreciating the looks even when you are not.
