Old 04-04-2015, 10:53 AM   #11
lightweight and balanced rotating assembly
Hey, that work bench looks familiar.. I hear the guy that owns the place is a real ****************************!
And that built crank, it might cost 6,500.00 and have that ****************************'s name on it, but it is 4 pounds lighter than stock and won't snap in half.
Hello Jake,
Regarding to the 4lbs lighter than stock (billet) crankshaft, plus the balancing of the entire rotating assembly.
Would be possible to achieve similar results by knife edging a stock crank (removing weight) and thereafter balancing the entire assembly as well?
What would be the down side of knife edging a stock crank?
Is the main reason for having the lowest possible mass rotating assembly is to be able to sustain higher rpm with the less vibration? Making a stronger engine in the end?
Your comments are always appreciated, thank you.
