Old 08-11-2014, 07:12 AM   #5
Pdwight's Avatar
MOre info
I have been reading up on this, they are actually about 27 watts per side. They use what looks like a HID Ballast, but in actuality it is called a driver. More checking reveals it is simply a constant voltage and current regulator that will supply a constant +3V to the LED unit that has a tiny fan on the rear to assist the aluminum heatsink built into the lamp assembly. My concern since the total Max current draw is only 2 amps per side is will the rear cooling fan/heatsink fit inside our headlight assembly?
The light output looks to be roughly the equivalent of a 35W HID conversion. THe price is appealing and seems to average from 60 USD to 85USD.
Perhaps someone else will weigh in on this with some actual hands on experience.
PS this looks to be a newer form of Cree called a "COB Cree array" and is much more efficient than what we have been seeing in the past.
