Old 03-11-2020, 10:17 AM   #21
Thumbs up
Originally Posted by SlowernOlder View Post
You need to remove the tail housing to replace the seal as the shaft is secured inside the transmission, might as well replace the bushing as it is the reason the seal is leaking.
Roger that, Slower! Thanks for that!
2006 911 S (sold) - 2003 Boxster S (driving)
ItsABoxster is offline   Reply With Quote
Old 07-19-2026, 01:20 PM   #22
Am I reading this thread correctly? The OP made his own direct oil fed IMS bearing with a $13 part??
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
Danimal is offline   Reply With Quote
Old 07-20-2026, 04:54 AM   #23
No, I believe you missed his earlier post where he mentioned the source of the kit. He then mentioned the bearing he is using with the kit.
-H. L. Mencken
