Old 04-10-2014, 07:40 PM   #1
evo-r's Avatar
Question Pressure bleeding brake fluid
I'm planning to pressure bleed my brake fluid soon and thinking of purchasing the following items from Pelican Parts for this job;
- Black Label European Power Bleeder Kit ($69.95)
- ATE Gold Brake Fluid x3 liters ($15/liter)
Questions:
1) In addition to the instructions from PelicanParts do you offer any other tip for this job? Pelican Technical Article: Bleeding Boxster Brakes - 986 / 987
2) Is "ATE Gold Brake Fluid" a good fluid to use? What color is this fluid? Any other good alternatives?
3) I thought I had read somewhere that it only takes 1 liter of the brake fluid to bleed the system but Pelican Parts states a minimum of 3 liters, which is correct?
His: 2003 Boxster & 2008 MDX
Hers: 2011 Golf TDI
evo-r is offline   Reply With Quote
