Old 03-25-2014, 11:06 AM   #4
Brad Roberts's Avatar
What he said
Complete overkill. Fix what you have (or find a competent shop) the 2.5's have KILLER brakes when bled properly with good pads and good fluid.
Tidbit of info: The 2.5/2.7 cars have the same master cylinder as the BoxsterS/996. So when you install the larger calipers/rotors? You end up with a softer pedal than what you had with the STOCK black calipers
Sucky.
Want to step up? Install the 996GT3 master cylinder with the BoxS/996 calipers.. now you have something..
Topless doesn't know it, but we switched the big brakes in our Boxster pro car... and went back to the smaller ones!!
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
Brad Roberts is offline   Reply With Quote
