Old 01-04-2014, 01:17 PM   #1
Cat bypass pipes
Has anyone installed Cat bypass pipes? I see the O2 sensors are located at both the intake and outlet sides of the CATs?
Old 01-05-2014, 07:15 PM   #2
I am my own mechanic....
Timco's Avatar
Rear cat bypass pipes?
'08 VW Touareg T-3 wife's car
Old 01-08-2014, 05:49 PM   #3
Mine is a 99 2.5l is there more than one set?
Old 01-08-2014, 06:08 PM   #4
Johnny Danger's Avatar
If you delete the only set of cats on a 2.5, needless to say, the vehicle will be rendered non-emmisions compliant, along with CEL's.
Old 01-08-2014, 08:04 PM   #5
My Honda Civic didn't throw any codes when I tried a bypass. Are you saying the 2.5l will throw codes?
Old 01-08-2014, 08:24 PM   #6
Since the 2.5 only has one set of cats, unless you remap the ECU, it will not only trigger a CEL, but it will cause the vehicle to fail emissions/inspection.
Old 01-08-2014, 08:46 PM   #7
I have straight pipes on my 97 2.5 race car. It will almost definitely throw a CEL if you remove the cats and it will fail emissions.
For a street car you aren't going to gain much by pulling the cats, you will probably lose some low end torque in exchange for some top end HP, not a good trade off unless you are WOT all the time.
gavinyuill is offline   Reply With Quote
Old 01-09-2014, 07:43 AM   #8
Registered Boxster abuser
healthservices's Avatar
My Honda Civic ....
Old 01-10-2014, 10:45 AM   #9
Originally Posted by healthservices View Post
My first car was a 99 Mitsubishi Eclipse, what about you guys?
Black on Black 2001 Boxster Base
Clutch Masters Stage III Clutch
Luk Flywheel // IMS Retrofit // Rear Main Seal
alanqning is offline   Reply With Quote
Old 01-12-2014, 05:54 AM   #10
Timco's Avatar
'77 Pinto wagon.
Old 01-12-2014, 08:54 AM   #11
73 Opel Gt!
Old 01-12-2014, 12:24 PM   #12
Porsche9's Avatar
68 mercury Cougar with 230,000 miles. Needless to say I ended up rebuilding the car. When you are a kid with some skills and little money you work with what you got. Made fats in a straight line but never handled for much even thought I did do some suspension work.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 01-17-2014, 09:14 AM   #13
steved0x's Avatar
'77 Pinto wagon.
Me too, late 70's turd brown pinto wagon with no ac in fl. Then a 77 turd brown Buick lesabre... My parents loved turd brown apparently. First car I bought with my own money, a red fiat x1/9 for $500. It needed some work...
