Old 11-11-2013, 09:57 AM   #21
steved0x's Avatar
This is a very interesting discussion and I just found the other big thread by TRK on using the bigger TB and Plenum. Very interesting stuff.
Steve
Old 11-11-2013, 02:03 PM   #22
As JR posted the head castings are the same, & all bolt bosses are there. You just have to drill & tap the holes for the intake & exhaust parts you are using.
986 3.2 head has untapped bolt bosses to mount heat shields in 996s
Yes, I am aware of that. That's exactly what I did, but you make it seem ALOT simpler than it actually is. Being that both of my engines were out, I made a template for the 2.7 manifold and outlined the holes on the 3.4 head. I then removed the heads, and drilled the mounting bosses on a drill press since I wanted them 100% accurate and straight. I set up levels, used a lot of shims under the head, and then clamped it down to the machine to make sure the drill bit was exactly 90 deg to the hole I was tapping. Since it was a used engine, I didnt mind changing the valve seals and lapping the valves anyway.
I dont know if I'd have the nads to just take a home depot drill into my engine bay and try to drill the holes for the 996 manifold, but im sure it can be done.
Bigsmoothlee is offline   Reply With Quote
Old 11-11-2013, 02:06 PM   #23
Originally Posted by JAAY View Post
Yes a 987 engine cover fits. I have one on my 3.4 conversion so I didn't have to lower the engine.
Jaay, did you have trouble with the shifter cables being too short when you installed the 3.4 manifold without lowering the engine?
Which 987 engine cover did you use? Was it from a Cayman/Boxster S?
Old 11-11-2013, 02:14 PM   #24
BYprodriver's Avatar
If you put 3.4 heads on a 2.7 you lost compression ratio & undoubtedly low rpm torque due to the bigger valves.
Old 11-11-2013, 02:58 PM   #25
Engine Surgeon
Hmmn, what head gasket was used? With the difference in bore size at a whopping 10.5mm of bore size difference I'd expect issues. What cams were used with this?
I think he is stating that he had a 2.7 and did a 3.4 engine conversion...
US Patent 8,992,089 &
US Patent 9,416,697
Old 11-11-2013, 03:13 PM   #26
I bet you are right Jake, he did say he had 2 engines side by side in his post. Happy Veterans Day Jake & thank you for your service, both abroad & on Raby hill !
Old 11-11-2013, 04:27 PM   #27
Yes, that is correct. I did a full 3.4l conversion, but drilled the mounting bosses in the 3.4 head to attach a 2.7 intake manifold to it. This allowed me to avoid lowering the drivetrain. I drive my car to work every day and the roads here in the Northern NJ/NYC area are atrocious, so lowering the engine 1.5" to accommodate the 3.4 manifold was a risky proposition. One raised manhole cover and bye bye engine!
I want to install the 3.4 manifold with a 987 raised engine cover, do all of them work or is it only the "S"model that has the raised portion for the intake manifold?
Old 11-11-2013, 06:34 PM   #28
golonaus's Avatar
same here
987 cover got nice bump in the middle. you just need to trim off some of the carpet padding
99' with 3.4l engine. ROW tune. SAI delete
Old 11-11-2013, 06:40 PM   #29
golonaus's Avatar
dont know about Jaay,but In my install yes cables are too short
just a bit tho
Simple solution is to move shifter console about 1/2"
I drilled new mounting holes and shifter boot covered it
looks and works as it should
I'm curious how Jaay solved it too, tho
btw
I'm using cover from a cayman s
Old 11-12-2013, 05:29 AM   #30
JAAY's Avatar
I ran my cables under the intake manifolds.
Old 11-12-2013, 06:09 AM   #31
Originally Posted by golonaus View Post
same here
Excellent, thanks.
Did you use a 987 S cover or a standard 987 cover? I see both have raised bumps, I wonder if they're different?
I didn't think it was possible to run the cables under the manifold until now... Thanks
Old 11-12-2013, 06:27 AM   #32
JAAY's Avatar
I don't know what cover I used. I think there the same though.
Old 11-12-2013, 06:40 AM   #33
The Radium King's Avatar
make sure jaay hasn't deleted his AC ...
Old 11-12-2013, 07:03 AM   #34
JAAY's Avatar
My a/c is still in. I have my top up mostly. It gets hot here.
Old 11-12-2013, 11:56 AM   #35
Nine8Six's Avatar
What all else does Porsche do differently in the 911 such that it has so much more power, and why can't we do that same stuff in the Boxster?
Steve
You can! Get 6 (six) custom ultra-light pistons machined out of titanium (e.g. the flat piston style, F1 tech, same as in the GT3), and get a tuner to design/machine you a set of cams with tad rounder/longuer intake lobes. If you have the cash, you could also get your crank re-machined and ballanced for the flat 6. Custom mapping and all, big big roars
A small and modest $20,000~$30,000 mod (350~400bhp)!
Horses are not cheap these days mate. Hence the higher price on those upper Pcars models.
Old 11-12-2013, 12:53 PM   #36
Y
I beg to differ. The power was intentionally left out of the 3.2 for marketing reasons... My 3.4 986 humiliates non-gt3 996s at autoxs
Old 11-12-2013, 02:36 PM   #37
woodsman's Avatar
what's that got to do with horsepower?????
Old 11-13-2013, 04:10 AM   #38
The lack of power wasnt from a lack of funding, it was done intentionally to keep a gap between the 911 and the Boxster. Equal power ususally results in the 911 having its ass handed to it by a boxster
Old 11-13-2013, 08:54 AM   #39
Engine Surgeon
That 2.7 intake is killing the potential of that engine. The 2.7 intake is inadequate even for a 2.7 engine.
US Patent 9,416,697
Old 11-18-2013, 06:27 PM   #40
jaykay's Avatar
Jaay does the cayman cover mess with the soft top? Were you able to adapt ithe insulation cover to fit over it ?
986 00S
